zomvid
- Dec 11, 2012
Okay, I don't have much hopes in the Sony XB500's. I am currently listening to the Crossfade LPs, and man, you can tell that the LPs have a better SQ than the XB500's.
I'm seriously considering to pack it up for now and return my Sony XB500's. Then, I might get headphones on Christmas.
and they will last so much longer than the sonys... ive even worn my lp2s in the rain.
Yeah, I see. I think I might go with the M100's for Christmas, if my mom doesn't say that it is not worth it or any other crappy stuff...
EQ bro.
And dubstep barely sounds different on Flacs and they cost money, unless you wanna pirate them and its extremely hard to find dubstep in flacs, just get 320Kbs files, they are only a little worse then FLACs in SQ.
The XB500s will sound great with a little EQ!
They should rumble and shake on your head.
Unless they are fake? Because ive never heard someone say that the XB500 didnt have enough bass![]()
Dear Haitek, just download winamp and try it out first, or foobar 2000. trying wont hurt![]()
Also do eq, it really is a very good way to improve your sound for free.
And personally i think the XB500 does not have enough bass. XD
The subbass department fell short for me, midbass and highbass was though... excessive![]()
In short: eq, it is very good for you.
(note it can't play png and jpeg files though)![]()
Honestly, I'll be happy to return the XB500's and keep the Crossfade LP's until Christmas. To be honest, the Crossfade LP's sound is really not bad. And also, it has that alien hard-plastic case![]()
Just keep the XB500s so you dont get bored of the LPs. If tou EQ, it sounds so much better. I implore you to get Winamp and get that bass up![]()
your trying to bass boost an already bass boosted headphone. sounds funny to me
