I do own a pair of susvara and they are one of my favorite pairs of headphones yet very very difficult to drive properly. Curious what you are using with your pair... assuming you own a pair?
I had just tested susvara with the hpa4 and have to give it a solid thumbs up!
It does require it to be near maxed out but it doesn’t sound thin whatsoever like most other amps. This truly does make the susvara sound very good and to their true potential imo. I am running with about a 4dB boost and maximum line in volume. And about 85-90% headphone volume depending on what I listen to. Getting close to solid 95-100dB which I rarely ever listen this loud but the susvara is capable of sounding extremely clean with this amp. Likely 110dB is possible and not sounding thin or shouty which is what I’ve experienced when using susvara’s with about 98% of headphone amplifiers. I’m picky....
The hpa4 can be up to 10dB boost for line in, and I didn’t use any boost at first and found myself nearly maximum line and max vol... but now am using 4dB boost like I said. Gives me enough headroom for classical... barely. Modern music you will have more headroom of course.
But I won’t mention names of other amps.. I’ve tried most amplifiers and several even more expensive than this hpa4. Only a handful of amps can power susvara properly and that are under 3K.
Albeit the hpa4 may get the susvara there, I’m surely not listening that loud. I usually am around 80-85dB and this amp allows the susvara to sound full and proper. (Thumbs up!) when the amp is not proper for the susvara then they will sound thin or shouts, usually top end is bright and miss and bass recessed a bit.
I was truly worried, since I had tried some other thx amps that simply did not cut it for the susvara imo. The hpa4 is the flagship with thx 888 dual mono and significantly more powerful, yet expect that you won’t have a ton of headroom yet the sound quality will surely please you up to very reasonable levels.
My two cents. Hope this is helpful.
Wonder if there would be more headroom with the speaker amp AHB2??
