Hi joijwall,
Originally Posted by joijwall /img/forum/go_quote.gif
How do I record and compare S/DPIF-output and CD-source?
Well, the effort actually depends on the data rates you're trying to compare. For instance to do that for 96kHz/24Bit or even 192kHz material, one will face mainly two problems: The equipment capable of recording that rates over S/PDIF, source capable of deliver such rates over S/PDIF and of course the old annoying topic copy protection.
But let's stick with 44.1kHz/16Bit for now like it comes from regular audio-cds. The deal would be to record the player's output with a sound card featuring a S/PDIF input (~ 20 EUR) and compare that result with the files you get via DAE (Digital Audio Extraction) from your CD.
If the output of your player is bitperfect (unfortunately not all are, sad but true) and the transmission is fine, both files (the recorded one and the "ripped" one) should match. There might be missing / repeated samples, also sporadical within the track (I encounter this with my Transit USB, still have to investigate the reason) but the proofe is still valid.
What do you say about my presumptions that HDD reads data better than a CD player, and that DAC1 should convert extremely well?
It depends on what you mean by "reading better". On physical layer, every readout or storage is analog, hence varies in quality (for instance, when reading a CD a high-frequency signal is digitized and processed further) but at the end, what counts is if the "user data" (the raw data before the error correction stages may contain errors) is free of errors or not. There are debates about different amounts of jitter though. However, this doesn't affect the data integrity when within the threshold levels.
It's easy to hear difference between a Linn Majik CD and Linn Akurate CD. Shouldn't I hear some difference between Linn Majik CD and MacBook/DAC1? Thanks! Joachim
If you use different players or DAC configurations, the sound may be different although they are fed by the same data, yes.
Even if it might be bad for your stomach one hint at last: The undoubtful exclusive and well produced Linn players - and even if their drives are of highest quality materials - won't deliver you other data than the cheapest, rattly PC CD-ROM for ~ 15 EUR.
Amazing, huh?
