EliasGwinn
Member of the Trade: Velidoxi & Benchmark Media Systems
- Feb 26, 2007
edit: duplicate post...
Originally Posted by doctorcilantro /img/forum/go_quote.gif Since I have effectively turned the XLR outputs into RCA by floating the 3rd pin, does the +9 to +29 still apply? Or does the XLR output now conform to the unbalanced RCA specs: |
Originally Posted by vcoheda /img/forum/go_quote.gif elias: could you please comment on the difference in application between the coaxial digital input and the XLR balanced digital input on the DAC1. for example, if i intend to use the DAC1 with a balanced setup (amp and headphones), and use the coaxial instead of the XLR digital input from my music server to the DAC1, does this mean the setup is NOT balanced? basically, is there a difference between these two setups. 1. MusicServer (digital coaxial cable) > DAC1 (XLR analog cable) > Bal Amp > Bal HP 2. MusicServer (digital XLR cable) > DAC1 (XLR analog cable) > Bal Amp > Bal HP thanks |
Originally Posted by joijwall /img/forum/go_quote.gif I follow the bit-transparancy discussions with manic interest, although some/most of it is over my head. My listening experience using MacBook 10.5.2/iTunes 7.6.1/DAC1 USB compared with a very good Linn Majik CD is that I hear no or minimal difference. This is disturbing. Connecting DAC1 USB directly to my Majik CD makes the sound clearer and better in my ears. I'd like my Mac/DAC to perform better! Why? How? News? |
Originally Posted by riverlethe /img/forum/go_quote.gif Did you volume-match for this comparison? |
Originally Posted by EliasGwinn /img/forum/go_quote.gif L-e, Gordon, et. al., With the AD1896 (the ASRC used in the UltraLock clocking system of Benchmark converters), the jitter of the incoming signal will not affect the conversion, it will merely (and inconsequentially) affect the amount of data in the input buffer between samples (as l-e correctly stated). |
Originally Posted by EliasGwinn /img/forum/go_quote.gif L-e, the RAM in the AD1896 is 512 words per channel. |
Originally Posted by ted betley /img/forum/go_quote.gif Elias I hate to bother you but I tried j river and loved the sound through my Benchmark usb dac. However based on all the research I have done on the various sites it seems that folks prefer asio vs direct sound as an interface. I can get direct sound to work but not asio4all. Any advice on how to do that? I downloaded asio4all, followed the 9 page documantation, set audio output options to asio, chose asio4all and still no success. I get a 'direct show filters not available...'or something similar diagnostic and then my pc unselects the Benchmark as the ouput device (in the Asio4all panel) and it reverts back to direct sound. |
Originally Posted by little-endian /img/forum/go_quote.gif For instance it seems totally odd to me that some people try to reduce jitter at the transmission stage by changing cables, etc. while the problem arises during conversion and hence has to be fixed there as well. |
Originally Posted by little-endian /img/forum/go_quote.gif Does the term "words" equal to samples in this case, hence about 11ms @ 44.1 kHz or am I missing something? |
Originally Posted by little-endian /img/forum/go_quote.gif Besides that I've a question in regard to "bad data" sent to D/A-converters like the Benchmark DAC1: Can this do any harm? I mean especially in the case of the USB-version which is served by a PC where the data integrity is more prone to errors due to the source (file sharing, etc.). Don't get me wrong, I'm not referring to transmission errors between the USB-port and the DAC1 for instance but "bad data" by itself. In the worst case it could be white noise or audio with intersample peaks sent to the converter. Do the analog parts care about outputting totally distorted and clipping sound at all? |
