Elias,
First of all congratulations to the DAC1 Pre, I hope it will be a great success!
I'm still a bit shaky about the correct use of my DAC1 USB and I would appreciate your advice. I'm on a MacBook with the recent 10.5.2 and iTunes 7.6/QuickTime 7.4.1. As backup player I use VLC 0.86d, since you pointed out VLC earlier as very good.
1) Is there any difference for DAC1 if use the USB or the optical output from my MacBook? In the shop where I bought DAC1 they said USB is far better.
2) Will the sound from DAC1 change after some playing? I have the feeling that playback has become a bit "softer" compared to the beginning?
3) iTunes is my main player. But my impression is that VLC sounds "better". That is clearer, airer, more at ease. Is there perhaps some settings I missed in iTunes?
a) I use 24 bit and 44100 in CoreAudio, which I understand is the best setting for AppleLossless for both VLC and iTunes. I haven't seen in the wiki how VLC performs if I set it CoreAudio to 96000. Volume settings is disabled in my CoreAudio.
b) I've found the Equalizer Window in iTunes and turned it off (preset set to "Flat" just in case)
c) In iTunes settings for Playback I've unchecked Sound Enhancer and Sound Control.
d) iTunes volume is set to max
e) I've also found the picture/sound setting window in QuickTime, which has full volume, and balance, treble and bass in the middle. I can't find a way to turn it off, and I can't find the Equalizer although a setting is called "Show Equalizer".
f) VLC has volume set to 100% (256), equalizer and others off.
4) I've read in the wiki that iTunes uses QuickTime. Will QuickTime Player give the same bits to DAC1 as iTunes?
5) Are Apple interested in bit transparancy, or is that of minor interest for them?
6) When do you think your Leopard testing is ready for the wiki?
By the way, many of my hifi friends has suddenly become interested in a different approach back home after visiting me.
Joachim
