lowmagnet
- Mar 20, 2006
I won't be able to answer that question for you, since I'll be using the standard front outputs. If someone local has a pair of senn balanced cables, I could try a direct output out the back of the DAC1 to test that at least. I'm not really convinced of running balanced for short runs, especially since balanced headphones don't ground.
Elias stated that they tested on this platform, yes.
Originally Posted by schaqfu /img/forum/go_quote.gif My big fat dilemma question for all you geniuses on this thread now is: can I run balanced HD 650s directly out of the DAC1 USB now in balanced mode, without purchasing a separate balanced amp? |
Originally Posted by schaqfu /img/forum/go_quote.gif Ooh, one more question... did we ever get an answer on whether the DAC1 USB will definitely be able to work with Vista as it does with XP? |
