yourmando
- Mar 27, 2007
Unfortunately, this did not work. I've been troubleshooting more with the help of the Linkwitz Orion user forum. The DAC1, ATI amplifier, and active crossover/asp all have properly designed chassis ground (I'm not ruling out that one of the pieces is defective). This is unusual in that if only those 3 components are connected to the same power strip/socket, I get ground loop hum. And there are others with identical components with no hum.
The only solution I could find was to float the ground in either the DAC1 or the ASP/crossover (I did not attempt to float the amp). This breaks the loop and kills the hum. So I am leaving the ASP floated with a two-prong plug. This solves the problem, but I do feel like I'm "cheating."
Everything is still grounded through the shield of the interconnect, so I should be ok (I hope
Thanks again,
Armando
P.S. I'd also be interested to see some more Audio Precision type measurements on a Jensen, just out of curiosity. I love how the DAC1 has tons of performance measurements.
Originally Posted by EliasGwinn /img/forum/go_quote.gif Well, you could test to see if this eliminates the hum by using a scrap of wire and just touching the rca sheild to a bare part of the chassis. If so, then you could try something more permenant. Thanks, Elias |
Thanks again,
Armando
