Matias
bsckwan, I removed the player variable: my tests were done with an ASIO soundcard's SPDIF against DAC1 USB in WinXP. Same result though.
Originally Posted by Crowbar /img/forum/go_quote.gif Do you drive or take the bus or another gasoline or diesel using vehicle? A liter of gasoline is 9,000 watt-hours, 11,000 for diesel. Using a vehicle to go a single kilometer pales in comparison to electronic equipment's standby power for a whole day. |
Originally Posted by poo /img/forum/go_quote.gif DAMN! I didn't realise that (or at least forgot). Is that a limitation of USB within the DAC1, or USB in general? Can I ask for a simple explanation as to why this is the case? Something to do with bandwith? |
Originally Posted by yourmando /img/forum/go_quote.gif the other day I noticed some loud hum from the listening position. I use the dac1 usb as my preamp, and it's the only thing connected to my speakers (no cable box or other sources). I finally narrowed down the problem--if I plug the dac1 usb into a different wall socket from the other components, the hum mostly goes away. (Still audible from near the speakers, but I don't mind that). The 2 different wall socket situation is not ideal because I have 2 power strips coming in across different sides of the room. |
Originally Posted by erotisches /img/forum/go_quote.gif One question, if my PC is also a source for home theater, can dac1 be used simultaneously with the sound card? I also need digital out for the surround channel whereas ,if all output is fed through dac1, I will only have 2ch output. Digital output would be nice too ![]() Sorry if this is answered in FAQ, I admit that I haven't read it. |
Originally Posted by bsckwan /img/forum/go_quote.gif 1.) Mac OS X 10.5.3 with iTunes 7.6.2 playing AIFF files --> (via USB with 24 bit / 44.1 kHz setting in Audio Midi and standard USB cable) Benchmark DAC1 PRE Is there anyway to improve on 1 and whether this is usually the case with DAC1 - SPDIF better then USB? |
Originally Posted by 03lab /img/forum/go_quote.gif Anyway, I was more concerned about sending the DAC1 back for repair than power consumption in standby, as I always disconnect the power cord to my equipment when not in use. |
Originally Posted by Wavelength /img/forum/go_quote.gif Both Windows and MAC OSX have capabilities over 200Kbps with USB 1.1 protocols. |
Originally Posted by yourmando /img/forum/go_quote.gif Very interesting. No, I'm not handy with electronics. I'm a software engineer who has never soldered a thing. How would I connect the RCA shield to the chassis? |
Originally Posted by EliasGwinn /img/forum/go_quote.gif Hello Armando, First of all, I would recommend avoiding the transformer at all cost. It will add significant distortion, which will absolutely be audible (assuming your system is high-resolution)...Elias |
Originally Posted by Crowbar /img/forum/go_quote.gif Looking at the transformer specs, the phase distortion is not too bad, but the THD is unacceptable, especially at low frequencies. This is nothing close to transparent. Note also that they don't present a measurement of the hysteresis, which is a form of distortion specific to cored inductors... |
Originally Posted by EliasGwinn /img/forum/go_quote.gif This isn't true. I'm assuming you meant 200 Mbps, but even still, its not true. The highest data rate of USB 1.1 (Full Speed) is 12 Mbps. Thanks, Elias |
