Originally Posted by Ferbose
It seems that many of the digital sources are said to be better than DAC1, from $1k range products like AQVOX, Lavry, to cheaper ones like Storm, Zhaolu. Other DACs like Apogee mini, Bel Canto and Squeezebox are said to be at least as good. If I were to trust all the things I read, Benchmark DAC1 does not seem like a benchmark product at all, but a bottom-line product.
But I don't feel any of them is really better than DAC1. DAC1 has less fullness but lots of clarity, and its treble has a slight bite and edge that brings out details. Its bass is extremely well-controlled but lighter in weight. Which is more accurate, which is more neutral, which is more euphonic and which is closer to live music? I don't know and I don't know how to tell. DAC1 certain has its sound signature, and it is possible some don't like its signature. I don't see any apparent flaws in DAC1. With proper matching of downstream equipment, my system has given me sounds very close to live concerts so I have no complaints.
I was in a concert yesterday and the piano had pretty bad tonality due to half-closed lid and room interactions. Piano tone from my DAC1 to K1000 sounds more natural than that.
The fundamental and inevitable flaw of two-channel recording is the lack of ambience (it's the law of physics). This makes the midrange too lean, the treble too edgy and the bass too light and damped.
I don't think one can ever say DAC1 is bottomline or read it that way. I'd put it in upper mid-fi sound. It's in the back of the pack in a high tier IMO.
I would say people prefer those other DACs because of x, y, z reason. It's how they prioritize their sonic preferences. Given that more people like other units, there must be something going on there. Maybe people can't describe why they prefer it. It could be subconscious, they don't have experience, whatever it may be.
Quantisizing the quality of sources (or equipment in general), is a complicated task. I agree in saying it's hard to say others are better than DAC1 on objective level. There are some things other sources do better and worst. How it pans out depends on your preferences.
One thing that can take precesence is naturalness. Maybe DAC1 doesn't sound natural to most people now that they've heard other things. To me it's treble is not natural. Such tight bass is not natural. As for system matching, I can consider that hiding it's flaws, or enhancing it's strengths. The only time it's not is if the components in the system are as neutral as possible and that will be a difficult task for most people to acheive/acquire.
For your concert yesterday, the piano may have been off but there are characteristics in reality which should be taken note of. I try and match these to my reproduction system. Reality is the benchmark for me.
I believe lots of edgy treble and little bass is just a character of the component. Digital components have a greater tendency to have these trait IMO. It can be made not to sound like this though.
Originally Posted by Scrith
As someone who has carefully compared several recent DACs using A/B tests, none of these DACs really sound all that different, as it turns out...some give a bit more detail in the treble (which I think is a quality inherent in true digital sound reproduction), and some are a bit "warmer" sounding (much like the effect that can be achieved by using a digital equalizer--hardware or software--to slightly reduce treble or amplifiy the midrange).
In my experience you will hear MUCH greater differences between headphones or speakers, and even amps. In fact, I'd say, given a reasonable baseline of quality for the DACs in question, the difference between most DACs is somewhere between amps and the difference between headphone/speaker cables.
In practicalness, many things do sound the same I believe because there's a bottleneck somewhere. I dont' really think things should sound this way. Most people cannot find or remove these bottlenecks.
I find treble glare a trait of digital reproduction. I find it highly unnatural. I think it's different than EQ. I could EQ down the treble to reduce this glare but since I'm attuned to what it sounds like, I'd just notice it is still there just less. I rather not have the problem as oppsed to fixing it later.
Yes there are greater differences in sonics between headphones since it's shaping the sound in a larger fundamental way.
