I want to thank Todd for providing me with the opportunity to test the Bel Canto E.One streamer. This was particularly exciting to me because I’m just starting to explore network audio. I have been doing extensive research on Sonore Microrendu, Ultrarendu, SOTM SMS-200, and SOTM SMS-200 Ultra. My interest in a network renderer is purely to improve sound quality and eliminate any USB noise from the equation. I haven’t pulled the trigger because I’m simply very happy with my current setup.
Paul Pang USB Card V2 (Windows 10 PC) -> Wireworld Platinum Eclipse USB -> iFi Pro iDSD -> Soundaware P1 -> Hifiman Susvara. Both PPV2 and Pro iDSD are powered by Uptone JS2. All audio equipment are plugged into Audioquest Niagara 1000. I want to see how the E.one fair against my USB setup.
For testing the E.One, I tried the following, Coax from the e.One to Pro iDSD and RCA out to Pro iDSD. Pro iDSD only has miniToslink, so I didn’t get to try optical out or AES. From pure sound quality standpoint, streaming from e.One sounds inferior to PPv2 USB to Pro iDSD setup. It has less detail, smaller soundstage, less separation. It still sounds good just not great which was disappointing because one of the benefits of a network streamer is to eliminate noise, and Ethernet is galvanically isolated by default.
Even though the E.One is not advertised as a network player/DAC, I also tried to plug the E.One directly to the Soundaware P1 amp via RCA. This does work, but unfortunately it sounds even worse than the using the Pro iDSD as the DAC.
In terms of ease of use, the E.One was plug-n-play. Once I plugged in the ethernet cable, the Bel Canto app immediately detected the E.One. The best part of the app is that it allows you to connect to Onedrive since most other streamers don’t have that option. I happened to backup all my music to Onedrive. However, you cannot sort songs by artist, albums, etc. So basically you are limited to navigating to a folder and play music from that folder. The Tidal features in the E.One is somewhat limited. Also the app only works in portrait mode. I usually use my iPad Pro with the keyboard case. It was annoy that I can’t use it in landscape. I would only recommend using the E.One as a Roon endpoint.
In summary at $1600, I cannot recommend the E.One to anyone who is looking for a network streamer. You have so many other better options at this price range. I think the SOTM SMS200, SMS200 Ultra, Microrendu, and Ultrarendu will likely all sound better depending on your setup and are significantly cheaper than the E.One even after you add a LPS. They also have more choices for network connectivity like HQ Player embedded, Squeeze Lite, etc. I think at $1600, it needs to be a good network player not just streamer.
