schism630
- Mar 1, 2012
Hi everyone;
i'm new to the forum and just wanted to say hi. i hope i'm posting this in the correct section
Hopefully one of you skilled technicians can hep me out here; i have a Beats by Dre. Dre Tour and the rubber cable is beginning to break at the ear piece. The wire isn't broken yet just the rubber cable that supports is there anyway i could mend this bf it breaks the wire and i have to go spend all that money on some new ones.
here's an image of the break its in a tricky spot i'm thinking krazy glue or clear epoxy. don't wanna heat it as that may melt the plastic even further.
http://i.imgur.com/tlP82.jpg
