How many of you guys/girls have owned the Sennheiser Momentum Wireless 2.0's? After returning my H9's, I decided to get the 2nd generation H6 and I really like them but the sound is relatively flat. They seem very accurate which is great but I am almost willing to deal with harsher highs if I get more bass. I might be a tiny tiny bit of a bass head. I am curious if anyone has the Momentums and can comment on the volume of them. I want to make sure prior to ordering that they are LOUDER than the H9's. I would love if they sounded close to the B&W P7 Wireless but didn't hurt my head. If not, I may just return the H6's and wait for the new ones from Sennheiser or Audio Technica.
Thanks in advance!
Currently own both. Have owned the Momentums for ~8 months and the H9s for ~1 month. I recently went on a vacation and brought both.
For volume the Momentums are quite a bit louder. I cannot not tolerate them on maximum for a second. The H9s are still (imo) much too loud when full, but nowhere near as loud.
That being said, I personally feel that the H9s are quite a bit better. Much, much more comfortable. More lively presentation. More detailed - you truly can tell. Bass on the H9s is definitely more, so ymmv on the acoustics front. Some people will HATE the sound signature.
Only main issues are the volume (that's a ymmv, I don't personally find it an issue) and sometimes the bass on the H9s can overpower some other lovely elements to a song, but these situations are not overly common.
Momentums biggest assets would be the cost ($150-200 lower where I live), the great case they include and access (H9s required me to actually go to a B&O store). Also the lower bass can help to make them seem to present a larger soundstage but after A-Bing this I think it's more in your head than true. Cons are they do not sit as comfortably (although not bad), have some connection issues, a little less lively, and some reduced finesse to songs, just the little details.
Honestly both are great cans. For airplane use both are perfectly acceptable - cutting out most engine noise and leaving you with just your music. If you're after the Bose seal then look elsewhere, but in finding a good balance between ANC and SQ these are both great examples.
Summary - if the volume issues or price of the H9 is an issue for you then the Momentums are great too.
