- Oct 9, 2011
So does anyone know the frequency response range for the combo? Is it the same for the dac/pre as the amplifier section
One thing that hasn't been mentioned yet when comparing the Codex to DAC+Amp options is that you save money on an interconnect cable between DAC/Amp with the Codex. To get the sound quality of the Codex from separates, you'd need a high end interconnect. Also, there are obvious advantages to removing the extra interconnect cable and connectors from the signal chain.
This is true. If you compare to Schiit gear, you have the Mjolnir 2 and the Gungnir as your starting options for a fully balanced setup. That costs about $100 less than the Codex, though you have to add in the cost of the interconnect. If you move up to the Gungnir MB, then that exceeds the price of the Codex by a few hundred bucks. With all the talk of Schiit being a price / performance leader, especially for gear made in the USA, then I think Ayre has really hit a home run here. It's a fully balanced, no feedback, discrete design with a linear power supply and made in the USA. The SE output is just as good as the balanced outs (something that would be hard to claim for the Liquid Carbon) and is slightly more versatile with the preamp functionality.
I've got an all-Ayre system for my speaker setup (AX-5 Twenty + C-5xeMP) and I'm really trying to resist getting the Codex, but I'm losing more and more willpower as I type...
Hi, Yage,
I'm not trying to further erode your willpower, but I have to say that the Codex is even better in balanced mode. I was skeptical going in, and was very happy with it in SE mode, but when I went to balanced mode sound quality took a significant step forward.
I won't even consider it if it only goes down to 20.
Yes, I agree - I've listened to the Codex in balanced mode through my HD 600's. I was really bowled over by what I heard. Plugging in my ER-4S single-ended, though, was just as enjoyable. If I do get the Codex, I'm going to have to mod them to try the balanced output, but for now I'd be happy as-is.
Hi there Yage: any comments on Codex vs. Yiggy?
