music_man
- Jun 6, 2005
as usual i agree austin. the only thing i can see that i can improve now is going to lan. the lanrover is the best option but don't want to spend $600 than a grand on a cable. i know you wil say but i have all these cables i can afford. i said they were engineering samples given to me by others in the music industry. i did not pay a cent for maybe i have 300 grand of cables lol. you aproached this with audiophile components. maybe better i don't know. often audiophile components can be found on the industrial side too. as for the qx-5 i plugged it in the same cable setup. it did not change at all because it does not use bus power. bus power imo is crippling the codex. if you remove it/clean it plus clean the data it will unleash it imo. the data also suffers on the codex. not on the qx-5. the qx-5 is at a price people will expect it to work without playing these games. it is no doubt a better product overall but the codex i feel is at least on par as a balanced dac at this point. which is astonishing because the codex has a older noiser dac and overall not as good electronics. it just sounds really good to me this way. i have a bit of a feeling yours sounds even better. remember though my whole system is powered by filtered batteries. online ups. the ax-5 is small enough to do that. some 1000 watt mcintosh mono's no way lol. as for the ground i broke it at the computer and it works fine. power up/down many cycles to test. break it after the power(hub) you have problems. obviously with dc you need + and - for a signal. it does not have to originate from the pc though. just as long as it gets power. i unplug the power to the hub, the music stops and the codex reads usb. so i know i broke the connection at the pc. well, i cut the wires so of course.
i do not know about that psu above and if it would improve things or if the next step is to go lan. i think wireless is probably pretty bad but don't know. i will go cat6. as i also said a standard cat6 cable is probably better than the aq diamond usb. the aq diamond cat5 is probably the cats pajamas. usb is just not good at transferring data. this is in fact data not audio. improve the data transmission we improve the audio. i need to know about that psu before i go buy the rest of the parts to try it. not sure if it will get better. will be cheaper than lan. the old rs psu is very robust and super quiet. i measured it once dc to daylight and not a lot of noise anywhere we would be hearing it. just by memory it is better than the ifi wallwart. there are always some on ebay. i just pulled up a few. like $12-$18. i am saying startech because they are the only hubs with a full size b jack. not all of them. i am guessing the one that steps down from 12v is very quiet but i do not know about this psu brick. someone mentioned in diy somewhere wallwarts from a decade ago were mostly no good. mostly. that rs is from the 80's and is superb you can tell by the size for only 800ma it is not average. the codex only needs like 3ma to handshake. do not plug anything else in this hub or you will pollute it!
austin, we had different approaches but it would be interesting for us to hear each others results. unfortunately i am guessing i am nowhere near you. middle of nowhere wisconsin. 1/2 hour car ride to first business of any kind. this was my dream after chicago for 40+ years. you can imagine why. i am sure you watch the news about chicago. lucky i lived quite frankly. .
if anyone can tel me about that psu it would be much appreciated. want to try it but don't even know if it is any good. the old rs made a much quieter background. why did they have to use the xmos board? it is like a hog tie to this thing. i will go read that robi. perhaps next step is just lan. dang that cable is $$$.
