music_man
- Jun 6, 2005
edit: i was wrong. the ess9018k2m does indeed have a programmable filter space. it is locked as the only filter on the codex which is their minimum phase. same as qx-5. it is not on an fpga but it is there which is all that matters to me. the clock is in fact an outboard chip. since the ess9018k2m does not run asynchronous. it is one crystal vs. two in the qx-5 and not from moran. less quality than the qx-5 but it is there. plus their entire host of innovative features. starting with the fully balanced zero feedback architecture. it beats most $5,000 dacs and comes pretty close to the dave but that is not surprising as i mentioned dave is very overpriced. it beats the directstream as i had stated. others agree. just read through head-fi. so, i am unlikely to find a better dac that is marginally larger. i guess i can rest assured that it will just have to do. it took hours to figure out this information but perhaps i am just stupid or inept at using google. so that's that. looks like the codex is staying put. with very good cables and associated equipment it sounds extremely good. i have no faults there. i figured i could get better and i could. for starters the qx-5. the only issue is i do not have room for it. so this shall suffice. not that is a slouch by any means. the prat,soundstage,placement,shimmer everything.... it is all there. better? sure but not in this size box. quite frankly i do not know how they did this.
also, if i am looking at $9,000+++ dacs I do not want one with an off the shelf chip regardless of how it sounds. if i were ayre i would not have the big ess logo there. yes, it sounds amazing but you can do even better with in house production. hence the diamond dac v or vivaldi for instance. of course those are much more money than the qx-5 but $9,000 is not cheap either. the codex remains a great value. easily beating many $5,000+ dacs. I know i have done my share of bashing the qx-5 but do not need a $15 chip in a $9,000 dac regardless of how it sounds. plus justifying that i have no room for it but anyways for that sound quality i would be looking elsewhere personally. i do have the diamond dac v downstairs in the dedicated listening room. you can put the whole thing on an fpga at that price point as far as i am concerned. i do not want closed ended at this price. i do not state that the qx-5 does not sound good. contrary. it sounds great. so if that is what anyone wants i see no reason not to get one besides my personal hangups. ie, the entire dac on an fpga. meanwhile the codex is a serious contender since it can hang with $5,000+ dacs in many cases putting it pretty high up there. not one of the best dacs in the world but neither is the qx-5 imo. if you need the features great. otherwise the codex is a much bigger bargain.
