Avantone : Pro Planar
Aug 30, 2022 at 3:29 PM Post #1,351 of 1,500
Dekoni Nuggets have arrived, however, this concept is not understandable to me. The pads are way too deep and simply provide four stress points where before there was only a single one in the middle. Makes no sense to me, they should just release a headband. The headphones push up all the time, not the best comfort.
I think the idea is that having the nuggets placed in spread-out positions makes the hotspot distribute more evenly. So instead of just one intense hotspot in the center, you get 4 mild ones. But I also can't imagine something that thick working for me either. I have a larger head, so the nuggets would most likely make the headband too tight and put more pressure rather than relieve it.
Aug 31, 2022 at 1:13 AM Post #1,352 of 1,500
Instead, I came across aftermarket straps from Sennheiser yesterday, so for the HD515. These make much more sense to me and were attached in the headband and are also comfortable.
This is exactly what I did for mine (I posted about this long time ago in this thread) and it's really comfy, and cheap.
Aug 31, 2022 at 9:18 AM Post #1,353 of 1,500
On your recomendation I got one of those for my HE6se V2. Works great, thanks!
Sep 1, 2022 at 2:59 AM Post #1,354 of 1,500
Sep 1, 2022 at 10:16 AM Post #1,356 of 1,500
Sep 1, 2022 at 12:17 PM Post #1,357 of 1,500
Sep 1, 2022 at 4:31 PM Post #1,359 of 1,500
It seems to me that someone here had steel straps with the serial number below 500.
However, for safety I recommend looking for versions over 600.
Sep 3, 2022 at 1:05 AM Post #1,360 of 1,500
Sep 3, 2022 at 1:12 AM Post #1,361 of 1,500
Is it something you would be able to verify in this listing please?
https://www.ebay.com/itm/2951845697...tynMMIQSQu&var=&widget_ver=artemis&media=COPY
the serial # is below the UPC code
Sep 3, 2022 at 1:17 AM Post #1,362 of 1,500
Yes, I found that as well. But there's no way to confirm the steel replacements from the picture? I suppose since the SN is so low, it would be plastic
Sep 3, 2022 at 3:48 AM Post #1,364 of 1,500
Visually the two materials are almost identical, unfortunately from the photos it is impossible to help you to trace the type of strap. When you have them in your hands you have to press the strap exactly as I indicated in the photo of the link (above).
