bassd00d
- Aug 22, 2004
If I were you, I'd start all over (if you haven't already).....uninstall all sound drivers, for both the Audigy 2 and AV-710, remove the sound cards from the device manager, shut down, remove both sound cards, and maybe just install the AV-710 into a different slot.
Once you're booted up, install the correct drivers for the sound card. Before you start messing around with any settings, test out the headphones to make sure everything is working properly and it gets loud enough. Use default settings in foobar or winamp, with no plugins or anything.
If everything sounds ok, then start changing settings and using any plugins you want.
