Decommo
- Jan 24, 2016
HELP, PLEASE!!
Has anyone changed from stock 3.5mm jack to their own to fix the either side sound cut off issue? I am trying to do it so open up the cable and remove the insulation and found this..
Both side has red and black cables. Not sure which one is ground and which one is each channel. I guess that black is ground so I need to put both black cables together and each red cable is belong to each channel (red from right hand side is right channel and red from left hand side is left channel). Can anyone please confirm this for me so I do not make dumb mistake while soldering?
Thank you....
Thank you....
