Larryonfire
- Aug 16, 2011
Nice impressions, will be interesting to hear what you think after 30-100 hours of burn in Andrew. What does the Fox say ?
Have fun messing with balanced. To my ears, balanced is different, but not always better. IMO planars and other power hungry low impedance models do best from the SE jack, while less sensitive stuff (Audio Technica, Ultrasone) and higher impedance Sennheiser or beyerdynamic is better in balanced mode. Very nice to have both options.
Originally Posted by Wang Xuanqian
Experiment with either mode for different headphones. The largest power transfer does not automatically imply the best sonics. We for example prefer BAL mode for the HifiMan HE6 even though STD delivers more power into their impedance. While the Grado RS1 and PS1000 also operate at 32ohm, with them STD is better as it is with the now discontinued AKG K100. For the Sennheiser HD600 and HD800 meanwhile BAL is much better.
Hmm, seems like GS-1 has tighter and harder hitting bass, Taurus is a bit on a loose side with extra "bloom" there which makes it sound "slower".
Hopefully longer burn in will take care of that. Other than that they are incredibly close, much closer than Soloist and GS-1.
BTW, Taurus passed W5000 exam with flying colors, not a lot of amps can make them sound properly.
Just had MKII delivered. It just barely warmed up, still needs a lot of burn in. But initial impression is that voicing is extremely close to Headamp GS-1 with new modules (same as used in GS-X MKII).
Does anyone know output impedance on that thing?
Found an old email, no impedance but might be interesting anyway
The power in chart are continous RMS.
For your first question, there are four output sections in each Taurus amp. In STD mode, each two of them are in parallel driving one channel. It will well suite low impedance as the output current is plenty but the output power driving high impedance is limited by maximum swing voltage. In BAL mode, two section are in bridged connection(BTL), it will offering 2x maximum swing voltage so the output power at high impedance is four times higher, but at low impedance, since each section is bear half load which equal to 16ohm, the output is limited by output current. I hope this will help.
I purchased mine from Echo Audio in Portland, Oregon. http://echohifi.com/
Excellent service from Kurt at Echo. Give him a ring and tell him I sent you.
John
Some AURALiC Taurus/Vega impressions from RMA2013 thread
