Aune T1 USB Tube DAC+ SS Amp Discussion Thread ***See first post for FAQ--Updated on 02/14/15***
Feb 16, 2015 at 5:13 PM Post #6,751 of 8,309
  I have been reading around and haven't really found an answer. I have been using the AUne Tk1 MK2 for a decent while and am vastly underwhelmed. I think I gotexcited by the reviews and just bought a product that does not fit how I listen. First of all, the issues with USB 3.0 are devastating. My computer only has USB 3.0 ports and I don't have an option to switch them. My sound cuts in an out all day. (Anyone have any recommendations?) Overall, I'm not sure why I bought this piece, but I think solid states are just personally more my style. Does anyone have any recommendations of how to fix the USB issue though?
In your BIOS do you have the legacy USB option turned on?
Feb 16, 2015 at 5:21 PM Post #6,752 of 8,309
Feb 16, 2015 at 5:33 PM Post #6,753 of 8,309
Hey man, I'm really sorry to hear you've had a bad experience with the T1 mk2. I've been using version 1 since the beginning, so I'm not familiar with the quirks of the mk2. However, I'll look around for some troubleshooting tips and get back to you.
Feb 16, 2015 at 5:49 PM Post #6,754 of 8,309
So, I saw your post on reddit freeryder ...looks like you might be out of luck.I have no idea if this would work but what if you tried plugging a powered USB 2.0 hub (has a wall power plug) into your USB 3.0 slot?
Feb 16, 2015 at 6:08 PM Post #6,755 of 8,309
  It is enabled. I just checked again.
Do you have access to any computer with USB 2.0 ports?  A friend? Work?  That way you can check if this is an issue with USB 3.0 or if it is an issue with the T1 MK2.  How long have you had the T1?
Are you using a desktop?  If so what is the motherboard or what is the desktop model/manufacturer?  If it is a laptop what is the model/manufacturer?  I'm curious to see if all your ports are Intel PCH or if you have something like an Etron chipset along with the Intel ports.
The T1 does not draw any power from the USB port (some owners actually cut the 5V pin), so power from the port is not an issue.  USB 3.0 should not be an issue either, but I have seen many devices act strange in a 3.0 port at work, so it's possible.
Feb 16, 2015 at 7:17 PM Post #6,757 of 8,309
Wow (again). The Miniwatt sounds really nice with the HD650. Even with the stock amp (which I've never really liked with the HD650).
The HD650, more than any other headphone I've tried in this little experiment, REALLY excelled with the T1>Lyr setup. As usual, it was the most analog sounding of the 3 test setups. I think what I liked about it was that it was kind of an overdose of the warm/lush sound, but not veiled at all. This is definitely my new favorite combo for the HD650.
Feb 16, 2015 at 10:43 PM Post #6,761 of 8,309
Just use a cheap non powered or powered usb 2.0 or 3.0 hub and you are sorted. It's a well known issue usb 3.0 and audio gear often causes problems when connected directly. Don't ask me for a technical explanation but I had these issues with a lot of DACs over the years and all worked just perfect in the hub.
May I ask what else is underwhelming with you T1? It's a very powerful 1000mW solid state amp. Try using the dac portion alone via line in so you can see if there is something wrong with the tube for the DAC.
Cheers,
K
Feb 16, 2015 at 11:03 PM Post #6,762 of 8,309
Cheers,
K
Thanks for all the input and help. Right now I just don't find I really get the maximum use for it. I am mobile most of the time and honestly I don't find the sound is much better than my e18. The warmth and source in the aune is unreal, but I just can't really find a way to justify the cost of what I spent on it. I mean right now all I use with it is 598hd and I just don't hear enough of a response compared to my e18.
Feb 16, 2015 at 11:30 PM Post #6,763 of 8,309
While I don't have the e18, I have a fiio X5 and previously an X3 and of course the marvelous HD598. Just listened to it yesterday night after upgrading the cable and my goodness this headphone was long neglected in my stable but not anymore. Amazing sound.
But indeed it's driven totally fine from the e18, the differences are microscopic at best to the T1 since the HD598 is really easy to drive and gets all it needs to sound great from the e18 already.
Things change with T90/T1 or Hd600/HD650 though, there you really need the juice from the Aune T1.
Cheers,
K
Feb 17, 2015 at 4:35 AM Post #6,764 of 8,309
  Hey fellas, so I decided to make a trade for an Asgard 2. Naturally, impressions will follow when it gets here.
Hello, congratulations!
We are waiting your impression here.
Feb 17, 2015 at 11:52 AM Post #6,765 of 8,309
If you are running it mobile, are you just using the Line In on the T1?  If so you aren't using any of what the unit is known for (the DAC with the Tube Buffer).  Like a user above mentioned, you can run this with an OTG cable to USB on an android device.  Doing that would use every part of the unit vs. line out that only uses the amp, which isn't what people buy the T1 for.
Assuming you just purchased it and that is your impressions on the T1 vs. E18, then I'd return it.  The T1 isn't for everyone, although there are very many people who love the unit, especially after upgrading the tube and the capacitors.  Although you do need some experience soldering to replace the caps, but it is very simple and most people landed on the same capacitors in terms of the sound signature they produce (Panasonic FRs and ELNA SILMIC IIs).
I noticed you are running Garage1217 Project Sunrise, I considered building that, but decided to go with the Magni 2 for the portability.
What do you think of Sunrise?  How does it mesh with the Aune T1?  Eventually I'll get a higher end amp and I am looking closely at Garage1217's products, especially Project Ember.  I may go with something that is fully DIY (not a kit), but I am curious how Sunrise does with the T1.
