Paspie
- Jan 26, 2013
I'm on openSUSE 13.1, my laptop is a ThinkPad T510.
Yeah, D8 and D11 are definitely per left and right channel.
Ohming out the stock dips, on is completely closed (has 0 ohms), and off is completely open (high resistance). (I'm ohming from the solder joints under the dip switches... from "1" across to the "On" side, and "2" to the "On" side.)
You could easily check the dips you installed the same way... I'm also reading continuity from 1 to 2 on both dips.
As for the DAC and RCA amp, it should operate 100% fine without the headphone amp board installed... you can pull the headphone amp portion out, and plug the RCA outputs to another amp and everything should work fine using the USB input. If that doesn't work, something is shot on the main board.
Kind of hard to diagnose without a schematic, and since Aune doesn't have one posted, someone would have to find a way to trace everything out and draw a schematic. You could try emailing Aune and requesting a copy of a schematic... Let me know if you want me to make any other readings that may help.
edit: ok sounds like your DAC/amp portion is working fine, just have a problem with the headphone amp. Order another one from Aune maybe? @creatip ordered one for $8...
http://www.head-fi.org/t/633006/aune-t1-usb-tube-dac-amp-discussion-thread-see-first-post-for-faq/6465#post_11160858
I just found the problem with my amp PCB, I've got two resistors that are damaged. I guess those green lights don't mean that much..
No idea how that happened, but I'm definitely going to need one of those awesome $8 PCBs!
Uuurgh.... still waiting for my 6N23P-EB tube..... It takes long...
So far loving my T1, but just want to try warmer sound on my K7XX. Is there any (cheap) tube that colors the sound?
Any tube will color the sound. That's the main reason people go with tubes, and consequently the main reason purists (those who're seeking to get the most transparent audio as possible) hate tube devices.
Vokshod should be cheap and warm.
@Rozenberg
I highly suggest a Holland Amperex Orange Globe 6DJ8. They're relatively cheap and not far off sounding from the more expensive (some consider top of the line) Amperex 7308. I wasn't so keen on what different tubes would sound like, but the difference between the AOG 6DJ8 and the EH6922 is literally night and day. I'm so sure of it that I will buy your AOG 6DJ8 off of you if you don't like it.
Can It be used with 9V batteries with some adaptor like this one?:
http://www.ebay.es/itm/390939552444?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
Can someone give me the resistor values for R58 and R59 on the amp PCB? If I am lucky they are something common and I have through hole resistors that will work in my collection.
Although, I had my mind semi-blown last night once I had the amp PCB removed from the T1 and ran it through my Yamaha RX-V863. I guess having two blown resistors on the amp PCB was introducing noise into the circuit, even when using the line out.
Once I removed the amp PCB and tried a different line in on my Yamaha the T1 suddenly sounded better than I have ever heard it before. The sound signature was warmer and had a fullness that was lacking before. Also keep in mind this is with a new set of HP150 headphones that haven't even been broken in yet. There is no doubt once I have the money to spend on more audio equipment I will get something like the Schiit Magni. That $8 amp PCB is definitely the bottleneck of the T1, but for the size of the unit and the price, I understand why they had to go with such a weak amp. Is there something a little cheaper than the Schiit Magni that you all would recommend for pairing with the T1?
Bringing this up since we're talking about the gain dips lately...
I always heard everyone who was asked on this thread recommend using the highest gain setting for higher impedance headphones (like the HD-650's, at 300 ohms nominal impedance), so I had my dips at +16db forever... recently I decided to put them back down to 0db just to see if it made a difference...
I'm almost certain it has made a difference... I hear more audible decay especially with vocals (reverb that wasn't audible at +16db). It also sounds more "tubey" and less crisp/solid state. I hear a noticeable more amount of "bloom" which really makes me think setting the gain higher might be compressing things somehow, and/or resulting in a minor loss of dynamics.
I have the volume pot dialled much higher than normal, to achieve the same listening volume as usual, but I still have plenty of room, so I'm leaving my dips at 0db. I prefer this sound.
Would enjoy having some impressions from people who were also rocking 8 or 16db and try going back to 0db for a bit. (I would also love doing a blind listening test as well... any idea if the dips can safely be changed on the fly?)
edit: Also reminds me of a wicked little experiment I might try this year and involve everyone in... I'd like to find something that can record in decent quality and swap different tubes through the T1, then allow people to download clips with different tubes and try and match the recordings to which tube they came from. If I ever do find something capable of recording in decent quality, I could try comparing dip settings on the headphone out... but that may be tough going headphone out -> recorder. (might mess the headphone amp up driving into the recorder)
edit 2: this sounds much, much better. I'm hearing lots of details I never heard if many of the songs I listen to daily... little bits of guitar/piano/bass in the background of Stan Getz - Girl from Ipanema, as well as much more details in the vocals throughout the song... I think 0db has definitely improved the T1 for my headphones considerably.
