MrEleventy
- Oct 24, 2012
Remove the rubber feet on the bottom and unscrew the 4 screws. It should come apart easily after that.How do I take apart the t1?
Do you mean the top lid? Taking the top lid off requires removing the volume knob and unscrewing the hex nut that's holding the lid to the pot.unscrewed the 4 screws (and the one on the back, in the middle of the RCA in/out), but somehow i cant really take it apart. i mean, i expected the top to come off but its stuck with the whole unit. The reason i want to take it apart is because i was doing the colored LED mod and accidentally dropped the tiny piece of paper inside the unit lol. Do you think that would affect it?
Sorry if this has been discussed before, but I just got my T1 and every time i turn it on, my Windows volume gets set to 50%. I can turn it back up to 100% but I'm curious as to why the volume changes when the T1 is turned on?
Looking at face of connector with all pins on the bottom and arrow at the top, far left and far right I measure 35V AC. Either far pin to the very middle bottom pin I measure 17V AC.
I don't mean to curse, but **** man these things are getting ****tier. Is the QC sleeping. Mine runs well aside from the channel imbalance from the DAC portion. Others who buy the earlier batches have no major problems too.
I'm using the T1 via USB with a 2012 Macbook Pro running osx 10.8.5.
While plugged in it constantly forces the native volume control up to 100% leaving this image displayed on the screen:
http://www.osx-e.com/screenshots/osxvolumepreview.jpg
