JohnFoe
- Jun 14, 2014
Just out of curiosity, has anyone tried using the Aune T1 -> Heed CanAMP. I thought I've seen the combination used before but I'm not sure and would like to know how it sounds.
Sorry, it looks like there are rather big, clear rubber feet covering the screws for doing that, so I'm going to contact the seller before I do permanent damage on the thing (which I really don't want to do).
Bummer, but it looks like earlier in the thread that someone else got a MK2 DOA as well...
Well, do you have a big difference between the top switch and the rear switch?
Because for me it's like night and day!
The top switch is firm and with a proper mechanical "click", while the rear switch just basically rattles.
The seller got back to me and said that they will contact tech... whatever that means...
The rear switch should be like the top switch.
Hrmm seems that quality control is definitely an issue. How was your heat issue Strat? Did swapping tubes help with keeping it cool, or are you still rocking the fan?
lol, I have removed that switch from the PCB and re-soldered it back in to get a better angle on soldering caps inside the T1.
I've been using the T1 as my primary amp for a few months now. I just started experimenting with running it as a DAC only, sending the line out to different amps.
My first stab was runnig the following chain: Mac> Aune T1 (line out)> JDS Labs CMoyBB> AKG K701
The results were incredible! You get the nice tube warmth and punchiness of the Aune and a bass boost which is absolutely perfect for the K701's (IMO) somewhat bland and bass-free sound signature. (Note: you should purchase the 2x 9v CMoy and specify your AKG model if you are duplicaing this experiment- the7xx models need lots of current). To my ears, the combined sound is gorgeous.
Anyway, I wanted to share my successful experiment with my fellow T1 owners and ask if anyone else has tried the "amp rolling" thing? What amp/headphone combos have you tried using the T1 as a DAC only?
I've tried objective2, Magni, Vali, darkvoice 336 and e17. objective2 and darkvoice are my faves
I'm running the T1 with a Holland Ameperex Orange Globe 1969 fed into a FiiO E9. My primary headphones are the V-MODA M-100 and the decreased bass and increased sound stage of the OG tube helps with the dark, closed sound of my cans. Lana Del Ray on this set up is incredible.
