Salvatore
- Oct 8, 2012
And this is the socket we have:
...6922 sounds a bit too intimate and close for me so I definitely need a clearer and wider sounding tube. Especially the vocals could be clearer (I use treble +2db with my E17).
Yep, looks similar to ours(socket). Why don't you just buy a new adapter instead of changing whole power cord?
Russian 6n23p Rocket logo
This tube is intimacy to the max. Warm, but not muddy. Forward sounding. Output volume seems higher than the other tubes I’ve tried. Very musical and engaging tube. It’s a fun listen for sure but it comes at the cost of some soundstage. Has a very punchy midbass but doesn’t have as much presence in the lowest bass notes. Has a kind of addictive tube sound.
Purchased here: http://www.boiaudioworks.com/6N23P
Too intimate? What do you mean by it? With 6922EH it already is very wide & spacious sounding. Too close and unclear? I think by clearer tube you mean that you need more foward & narrower sounding tube because if you take even more wider-sounding tube, vocals will get even more "lost" imho. Rocket logo 6N23P should be more narrow & foward sounding tube than 6922EH. At least reflector logo 6N23P certainly is and when to read internet reviews, rocket one also. But well, ppl hear things differently and maybe its also about K702 paired with Aune T1.
Even thread starter says following:
I think you bought worng tube if you want even more wider sounding than 6922EH.
Originally Posted by CoiL /img/forum/go_quote.gif
E: Btw, if you change the cord then don`t forget to change it to one that has FUSE because that UK plug has it!
That remainds me - IMPORTANT! - UK plug fuse should be changed to something between 0,5A - 3A fuse because in stock it comes with 13A fuse which is way too much!
http://rockgrotto.proboards.com/index.cgi?action=display&board=talk&thread=8297&page=15#125152
Haven`t tried K702 with Aune T1 but something tells me that its about those cans paired with T1 that won`t make spacious & airy soundstage. With HD-681 mkII + 6922EH its freakingly wide, spacious & airy - in a good way that vocals won`t get too distant.
http://www.aliexpress.com/item/FA035BB-AC-220V-SILVER-COLOR-Aune-T1-24Bit-96KHz-DAC-Hi-Fi-Preamp-Audio-Decoder-6N11/695543397.html I will write them whether It's bad or not, and tomorrow will try it.
There's something awfully precarious about Chinese sellers
