BenWaB3
- Sep 22, 2009
Thanks Rob. That helps me feel more confident as I get closer to pulling the trigger on this unit. Now back to page 73
Ben
Ben
For electronic, best tubes from my collection are Miniwatt-Dario ECC189 Chartres France (tightest bass & kick out of my tubes and same time goes very deep lows), JAN Sylvania 6922 green label (for EM with more acoustic elements + vocals), Amperex OG 6GM8/ECC86 orange/white prints (for atmospheric electronic music with large "endless" soundstage and 3D imaging) and also stock 6922EH tube is good if you like deep "flowing" bass and also large "sparkly" soundstage.
About Miniwatt-Dario ECC189... I shared a deal link to some ppl and isendono bought 3 of them with crazy good price. Hope he wrotes his impressions when he gets them and burns them in littlebit.
Those are very interesting indeed. Looking foward to impressions.
Edit: HAPPY NEW YEAR EVERYBODY!!!
Hey CoiL, thank you for this, just confirm me all those laps are compatible with Aune?
and can i damage DAC if i put wrong lamp (which is not compatible with him) ?
And spacequeen7 thank to you, i will order and this lamp (i think at the end will have bunch of lamps, until i find what i am looking for... )
thank you.
+1, I went down a similar path except the other way around. I found a dac/source that I was happy with first and amp rolled. I tried E10, E17, ELE, T1, and Modi. Chose the T1 and rolled a O2, E17, Magni, Tubemagic A1 and Darkvoic 336. I'm tempted to give the ODac, stoner and hifimediy sabre a shot but I don't think I'll be swapping out the T1 anytime soon unless I spend $500+. Ultimately, I want to get an audio-gd 11.32/15.32 or Tubemagic D2 for home use. It's tough to have a T1 as a home dac with a 3 y/o running around.You will always have that balancing act of tubes on tubes..but here is a good rules to follow,
If you are set with one piece of gear..your tubes give you the exact balance, then it is easier to add something else that is tube driven and balance out.
So for example, if you have a system (tube) and it is perfect to you, top to bottom, but you add an AUNE and it is a bit bright, then the answer is to get a less bright tube, In my case, the 6922EH leaned toward bright, the orange globe Amperex, bass heavy (boomy)...The GE ..Perfect (or damn close..lol...still experimenting)
But if you buy the AUNE and a tube headphone amp, balance is a harder task. Not impossible, just more difficult.
so a two tube head amps I like (way out of the price range
http://www.innerfidelity.com/content/icon-audio-hp8-mk2-tube-headphone-amplifier
http://www.innerfidelity.com/content/consonance-m10s-tube-integratedheadphone-amplifier
This one is pretty cool too..
http://www.ebay.com/itm/Rivals-Single-ended-EL34-12AX7-Vacuum-Tube-Amplifier-with-Headphone-Amp-function-/350923470029?pt=US_Home_Audio_Amplifiers_Preamps&hash=item51b4ab34cd
Now here is the deal...you blend your headphone amp with the AUNE..and it sounds a bit thin...is it the AUNE tube or the head amp input tubes ? You will figure it out, but you need a baseline.
One option, get the headphone amp first and use a source such as CD that you love. SO when you have the sound you like, add the AUNE and you are either good, or need an AUNE tube change...
Does this all make sense?
thank you.
What arco said. And If you're wondering how the 336 performs check out Headfonia for a review and maybe the threads here, although they're pretty dead these days. Feel free to PM me if you have any questions. I'll try my best to answer.Interesting ..little mixed reaction in this one from the other reviews ,makes me thing that combining Aune T1 with another preamp can make some tubes shine more then others ,as for Amperex I would agree that it can give to much bass,for me it's little to juicy/boomy
Thank you for the review
Can someone recommend tube amp that will compliment Aune T1 ?,I'm looking at DarkVoice 336SE and since it uses other tubes how would this affect the Aune ? I want some more options to choose from
Thanks
So the moral is...Anything with a tube is going to be a lovely journey in getting the right music "color"...LOL
MrEleventy...Yes, it can be QUITE a journey when finding the RIGHT tubes...
I started with a handicap in that I bought my Velleman used for 1/4 of the price. It had a series of Reflektor Plant EL34's...some new type 12AX7's and a NOS 12AU7.
It also had a HUM in one channel and a buzz in the other ...ARGGGG...It took two months and some assistance form friendly experts. Change around of some resistor values, etc. Resolder some points and better ground grounding. Then figured out (no one had before) why these units had a tendency to BURN out EL34's. Turns out the 6.4VAC voltage from the trannie was really putting out 7.6VAC !!! YIkes. Small resistor and she is at 6.5 each channel.
Then the 6L6GC tubes. That part was easy. It was finding the right Input tubes....
That's part of what makes tubes fun.![]()
+1, Couldn't agree more.![]()
Although... the misses isn't having any fun whatsoever.![]()
Aune T1 manual:
Salvatore thank you so much!!!
