vurtomatic
- Oct 16, 2005
I'm actually thinking just that, ie. get a powered USB hub from Best Buy. Seems like I'm out of options so I'll give that a shot.
Given that the T1 appeared and disappeared, there is a possibility the USB ports do not have enough power.
Aune T1 does NOT draw ANY power from USB!
Thanks, just did the search. Found some posts referencing Macs from toschek and zerogun.
However, at work, I tried all the USB ports on my Macbook Pro and the Cinema Display. At home, I had nothing else plugged into USB except for the T1.
And if I remember correctly Coil mentioned the T1 does not draw power from USB.
So I remain stumped.
Yeah I remember you mentioning cutting the connector for power in the T1? Anyway I'm out of options and no other theories explain why the T1 would behave like that. It's just really bizarre that it appeared intermittently on my work laptop, and on my home laptop it worked for 5 mins, and then disappeared after a lot of noise.
Hello everyone, first time posting in this thread!
So I just got my aune T1 and I want to know if this is an okay tube to buy?
http://www.ebay.nl/itm/1-NOS-1970-Holland-Amperex-Orange-Globe-6EH7-EF183-tube-/270578803035?pt=Vintage_Electronics_R2&hash=item3effc0e15b
NO!
Sorry but this is getting annoying already - PEOPLE, LEARN TO READ THE THREAD AND STOP ASKING STUPID QUESTIONS!
I can only assume my T1 is defective unless someone can chime in with a suggestion.
I've tried it on 2 laptops running Mac OS.
Tried different USB cables.
Now tried a powered USB hub. T1 doesn't show up at all with or without the powered hub.
I've even plugged the power supply into a transformer that steps up 110V to 230V.
And uncola reported his works fine with the T1's 230V power supply so I don't think that's the problem.
Previously at work the T1 appears and disappears. At home it appeared and worked for 5 mins. Now it doesn't show up at all.
It's just so bizarre. Never had an electronic device demonstrate such eccentricity!
