labeelen
Thanks, could it be that I am mixing up ‘bias’ and ‘quiescent current’ and that in fact the S17 is always operating in Class-A ?I think you are in class A driving 100ma.
The gain.do you mean it’s gain or Hi- and Low-Z switch ?
AB mode is in 50ma, 100ma is class A mode. The current level option allows you to switch these modes.Thanks, could it be that I am mixing up ‘bias’ and ‘quiescent current’ and that in fact the S17 is always operating in Class-A ?
Ok, thanks. With the S17 the gain change does not change the character and I cannot recall if this was the case with the SA-1.The gain.
Which is switched by switches on the bottom of Singxer SA-1.
Thanks, is there any reason/advantage of running in A/B (50mA) mode other than ‘reduced heat’ ?AB mode is in 50ma, 100ma is class A mode. The current level option allows you to switch these modes.
Mostly for sound signature if you can hear them out via your headphones that is. Sound signature as very subjective hence my disclaimer...Thanks, is there any reason/advantage of running in A/B (50mA) mode other than ‘reduced heat’ ?
I like the perforated rack!Got mine yesterday. Bigger than i thought and you don't want to drop one of these on your foot.
57 degrees was the most it got to, which equates to a barely warmish outer case. ( Though UK atm is pretty chilly )
Pleased so far, still 'burning it in' if that is even a thing.
my typo - Class A is inefficient.Mostly for sound signature if you can hear them out via your headphones that is. Sound signature as very subjective hence my disclaimer...
Technically Class A is generally associated to be not an efficient design from power consumption perspective but better perceived sound, Class B is efficient than A but introduces a bit more noise than Class A, so AB mode is supposed to be a mix of both giving best of both modes.
How they sound on this amp design and which one you prefer is an subjective preference.
Its a monitor stand,@ mrdbristol
What's the brand of that amp rack?
I share your quick thoughts, Aune made a very convincing statement with this product. I’m very happy with my purchase!Today I am a happy man, very impressed…quick thoughts, full bodied and spacious…easily an improvement over the already great headphone amp on the S9c which seems thinner and sibilant at times in comparison…is it worth paying another 700 usd for?? That’s subjective, but i certainly don’t see me using the amp on the S9c any longer, and i actually thought i would…fantastic job Aune!!!![]()
My room temp is 20 degrees, i don’t have much space between the amp and dac and I’ve been running the amp for about 4 hours now, the dac is even warmer than usual so i think it’s the fact that there stacked that has them a bit warmer, and yes there is a huge jump in volume from 55-56, along with a switching type of sound, but I’m never anywhere near there OfcorseI share your quick thoughts, Aune made a very convincing statement with this product. I’m very happy with my purchase!
… 63 degrees, at what room temperature ? (I have a room temperature of around 21 degrees at which the S17 max out at 57-58 Celsius)
btw did you also notice a larger volume increase/step from 55 to 56 on the volume dial ? (I’m aware that for most headphones you would never have to go near that level, but it is the preferred setting for my Hifiman he6se v2 in low gain)
