Dimitry188
It's very strange. I don't notice anything close to that on my device.The sound quality is terrible at any setting below 56 out of 63. At anything less than 56, it sounds totally broken.
Sound quality was never the issue with my S17, it is excellent at any volume setting.So, the big problem for me with the Aune S17 "wonky" volume behavior is: It's not just about larger than normal jumps in volume. The sound quality is terrible at any setting below 56 out of 63. At anything less than 56, it sounds totally broken. Muffled in a thick haze. Then when going from 55 to 56, it suddenly sounds open and beautifully detailed as it should. Even though I would have thought that with this much specified power, 56 would destroy my headphones and ears. Which on some tracks such with expansive dynamic range such as the excellent Janis Ian Live Tattoo, I am as high as 60 out of 63 into Ananda Nanos which are not hard to drive.
So, there are actually at least 3 issues with my unit:
Wonky jumps in volume control.
Anything less than 56 out of 63 sounds totally broken-completely hazy and veiled.
And, it doesn't seem to ever make it to what I would have expected to be max specified power or listening level.
You are the first with that kind of problem, honestlySo, the big problem for me with the Aune S17 "wonky" volume behavior is: It's not just about larger than normal jumps in volume. The sound quality is terrible at any setting below 56 out of 63. At anything less than 56, it sounds totally broken. Muffled in a thick haze. Then when going from 55 to 56, it suddenly sounds open and beautifully detailed as it should. Even though I would have thought that with this much specified power, 56 would destroy my headphones and ears. Which on some tracks such with expansive dynamic range such as the excellent Janis Ian Live Tattoo, I am as high as 60 out of 63 into Ananda Nanos which are not hard to drive.
At an environment temperature of 21 Celsius mine never exceeds 56 Celsius at 100mA or 46 Celsius at 50mA.At the moment I have not encountered any type of problem, as I said previously. The only thing I noticed, however, is that within about an hour the temperature reaches 69C and, for protection, goes from 100bias to 50bias. An hour to get to the cooking point seems like a short time to me . However, I honestly don't find any differences between 50 and 100 bias
Do you use xlr connection with dac, which volume the dac preamp? Do you use xlr connection to the headphones? At what volume do you ear? ThanksAt an environment temperature of 21 Celsius mine never exceeds 56 Celsius at 100mA or 46 Celsius at 50mA.
It is coming on Winter here and I keep my house at 16C. I have seen a temp of 65 once at which point I turned the bias down to the 50ma setting but it usually stays around 62. 100ma does sound substantially different than 50ma for me. but that could also be exacerbated by what seems to be a different issue with the S17 having to run nearly wide open to give the listening level I prefer.At the moment I have not encountered any type of problem, as I said previously. The only thing I noticed, however, is that within about an hour the temperature reaches 69C and, for protection, goes from 100bias to 50bias. An hour to get to the cooking point seems like a short time to me . However, I honestly don't find any differences between 50 and 100 bias
My S17 Pro is placed directly on top of my Gustard R26 DAC, connected via XLR. Headphones are HiFiman HE6se v2 via 4.4mm pentacon balanced at Volume 44 (100mA bias and Low Gain)Do you use xlr connection with dac, which volume the dac preamp? Do you use xlr connection to the headphones? At what volume do you ear? Thanks
Dac volume is Fixed?My S17 Pro is placed directly on top of my Gustard R26 DAC, connected via XLR. Headphones are HiFiman HE6se v2 via 4.4mm pentacon balanced at Volume 44 (100mA bias and Low Gain)
Please check your placement and ventilation. At a room temperature of 16 Celsius a well ventilated S17 would never go over 60 Celsius, imo.It is coming on Winter here and I keep my house at 16C. I have seen a temp of 65 once at which point I turned the bias down to the 50ma setting but it usually stays around 62. 100ma does sound substantially different than 50ma for me. but that could also be exacerbated by what seems to be a different issue with the S17 having to run nearly wide open to give the listening level I prefer.
I would honestly consider just abandoning the thought of using this amp and get a Topping A90D but those are also proving to be very unreliable for a couple different problems. And, the issues with that amp often do not arise until 6 months down the road. Which makes me doubt that even if you get a good one, that even 3 years later it will still be working.
Ok, so it seems like there shouldn't be anything above the Aune at allCorrect
Correct
It is sitting on its own place on a desk with nothing else near it. If I end up staying with a replacement Aune S17, I will make some taller feet.Please check your placement and ventilation. At a room temperature of 16 Celsius a well ventilated S17 would never go over 60 Celsius, imo.
