Aune S17 pro
Jun 4, 2024 at 2:38 PM Post #2,386 of 3,280
I read that 50mA and 100mA is entirely based on the headphones you use. For me, I notice zero difference on my LCD-2 Classics, but others insist there is a huge difference on their headphones (that are not LCD-2C). It might be worth creating a list of some sorts for headphones that are affected by the change.
There's a more noticeable difference with high impedance dynamic driver cans like the Senn HD600's series for example, I notice a little bit less of a difference with my LCD-X and LCD2C, is more subtle.
Jun 4, 2024 at 3:42 PM Post #2,387 of 3,280
Arya Stealth, HE1000SE. Change is there, but subtle. I doubt I'd noticed it on the fly. But it's definitely there :)
Jun 4, 2024 at 4:37 PM Post #2,388 of 3,280
Greetings to the community.
I'll warn you right away, English is not my native language.
I have been the owner of Aune s17 pro for some time now.
I like the sound of the amplifier.
I've taken some measurements
and they're depressing.
In any case, the reason for the dependence of the amplifier heating on the connected cable has become clear, as I understand it, this is a global problem. But I need confirmation from the community.
And of course it is necessary to get an explanation from Aune.
The main cause of overheating
Depending on the connected cable. This is the self-excitation of the amplifier at high frequencies. From 8 to 15 megahertz.
There are many more observations.
If you are interested, please support
P/S I don't know how to post pictures here.
Jun 4, 2024 at 5:38 PM Post #2,391 of 3,280
Hit this small button that looks like a picture and then drop the photos or click to search them in your computer or smartphone /tablet.
Jun 4, 2024 at 6:19 PM Post #2,392 of 3,280
Unfortunately, the function of attaching images is not available to me. Probably temporarily.
I'll copy the RAA result tables.
Here is an example of stable operation at low gain and unstable at high gain
Testing deviceAune B 1KOhm Hg 50mA D90III
Sampling mode24-bit, 48 kHz
Interface
Testing chainExternal loopback (line-out - line-in)
RMAA Version6.4.5
20 Hz - 20 kHz filterON
Normalize amplitudeON
Level change-0.6 dB / -0.6 dB
Mono modeOFF
Calibration singal, Hz1000
Polaritycorrect/correct
Summary​
Frequency response (from 40 Hz to 15 kHz), dB
+0.01, -0.01​
Excellent​
Noise level, dB (A)
-118.9​
Excellent​
Dynamic range, dB (A)
118.8​
Excellent​
THD, %
0.00766​
Very good​
THD + Noise, dB (A)
-80.0​
Average​
IMD + Noise, %
0.00839​
Very good​
Stereo crosstalk, dB
-104.8​
Excellent​
IMD at 10 kHz, %
0.00818​
Very good​
General performance
Very good
esting deviceAune B 1KOhm Lg 50mA D90III
Interface
RMAA Version6.4.5
Level change-1.0 dB / -1.0 dB
Mono modeOFF
Summary​
-0.00, -0.02​
Excellent​
Noise level, dB (A)
-121.5​
Excellent​
121.3​
Excellent​
THD, %
0.00008​
Excellent​
THD + Noise, dB (A)
-113.3​
Excellent​
IMD + Noise, %
0.00036​
Excellent​
-116.5​
Excellent​
IMD at 10 kHz, %
0.00028​
Excellent​
General performance
Very good
Jun 4, 2024 at 6:41 PM Post #2,394 of 3,280
That only will look depressing to someone who has bought other, more expensive, headphone amp 😁. Probably the bad news are yet to come😉
The sad thing is that the drop in performance is the result of interference at frequencies of 8-15 megahertz. The level and frequency depend on the cable, headphones. they work like an antenna to self-excite the amplifier. The interference level is very high.
Jun 4, 2024 at 6:47 PM Post #2,395 of 3,280
Honestly, i don't know what any of this means, is going above my head completely.
Jun 4, 2024 at 7:11 PM Post #2,397 of 3,280
in particular, this leads to rapid heating of the amplifier. The voltage of the parasitic signal can reach several volts. and in the case of high-resistance headphones or only a 10V Rms wire
I think I found this by mere accident by what I think you're describing here, with a particular balanced cable I had for my koss kph40, the temps went up crazy fast, also with my focal clears and the stock 4-pin xlr cable it comes with, but not as bad as with the kph40.
Jun 4, 2024 at 7:17 PM Post #2,398 of 3,280
That's not an overall problem - mine is completely cable agnostic: in 100 ma, it heats up to 69 °C in a bit less than one hour with any cable that I have (stock sennheiser, stock hifiman, stock focal, hart modular cables) or with no cable whatsoever connected.
Jun 4, 2024 at 7:39 PM Post #2,399 of 3,280
I hope this is not a common problem. But judging by the discussion, it is available. Unfortunately, not everyone can connect an oscilloscope and see what happens on the device's screen. Often, different types of distortion are taken by listeners as an advantage. :-(.... In this case, with a moderate level of interference, even harmonics, however, and odd harmonics, increase sharply. This leads to the effect of softening the treble and the effect of "beautiful bass", but these are distortions.
when I have the opportunity to post images, everything will be clear and understandable. (and sadly)
Jun 4, 2024 at 7:48 PM Post #2,400 of 3,280
Mine (without fans) gets hot just by being turned on (with just the power cable attached), and there's nothing that seems to change the heating behaviour (different cables, headphones, dacs, balanced/unbalanced, low or high gain). The only thing that matters is the current mode (50 or 100 ma). Even on 50 ma it gets to at least 62 °C.
