carps
- Jun 27, 2016
I use Sandisk formatted at FAT 32 through Fiio x5ii
Is the micro HDMI port going to be implemented as digital out?
I took some time to do a very rapid check of the new three available 1.30 firmwares in my M2S.
I used my FLC8S iems in red-grey-grey configuration (maybe in the future I'll do another test with senn HD800).
Digital filter was set to SH LD
M2-1.30
Aune description:
Ordinary firmware
This is the standard firmware and timbrically sits in the middle of the two others.
It's more resolving than M2_Chun1 but less than M2_Chun2.
For me the sound is to the extreme limit of starting to be cold.
The warm allure is not present anymore but voices are still organic and sibilants are never aggressive.
File order is by name.
M2_Chun1
Aune description:
Sound smooth and delicate for the human voice
Does not support APE FLAC MP3 compression formats
Support WAV DFF ISO and so on
The sound signature is very similar to 1.22 firmware, with that little bit of warm allure I love.
Midbass seems to have a longer decay than the standard 1.30 firmware.
Voices are intimate, sibilants are never aggressive but you loose some detail.
File order is by timestamp, the same annoying 1.22 bug.
M2_Chun2
Aune description:
Sound equalization / resolution / correct for instrumental music
Does not support APE FLAC MP3 DFF ISO format
Only WAV format is supported
Extremely clean and luminous, sounds are more shaped than the standard 1.30 firmware.
Timbre now remember the iBasso DX90, seems like AK4490 became an ESS Sabre dac.
Is very resolving, bass is very tight and fast, midbass is less present than the standard firmware.
Voices are less organic, a little bit drier.
Sibilants are more evident and sharp.
Not my cup of tea.
Overall I like the standard 1.30 firmware the best.
