Aune M1P
Jul 6, 2023 at 8:46 AM Post #91 of 593
Jul 7, 2023 at 2:46 AM Post #92 of 593
Ah yes - finally - the gapless works 🤟
Which was never the case on the m1s. Mine anyway 😂
Jul 7, 2023 at 5:17 AM Post #93 of 593
I must give it a try today! Are you finding M1p a reasonable upgrade on the M1s? My main frustration is the need to turn it off to avoid picking it up a few hours later and find it warm & dead 😬 😂
Jul 7, 2023 at 5:45 AM Post #94 of 593
Sound wise : yes :beerchug:
The m1p is an even more transparent, detailled, refined, balanced, dynamic, vivid (...) version of the m1s. Which is a real feat of strengh. Call me impressed.
With this :
Aune "M1p - LF filter" + Aure Audio "Ringo" ("Canal Works 肉球 Gel Narrow Bore" L tips / EA "Ares S Founders Edition - 4/10" 8-wires balanced cable)
My personal endgame. This ticks 100% of all my boxes. :heart_eyes:
Ergonomically wise : no :slight_frown:
The m1s, with its two buttons near the main control button, was (is) essentially perfect. The fact of having removed these 2 buttons on the m1p, is a real setback...
Turn off the gear : it was already the case with the m1s, so... :thermometer_face::sweat_smile:
So not a concern for me, as the system reaches its cruising temperature very quickly.
Some bugs, however, to be corrected.
For example, the bluetooth sometimes turns on because you have pressed the main control button at the bottom for too long... to normally do a "favorite track", instead.
However, it has happened several times that the DAP then... hangs. With obligation to restart. There is a sort of freeze... I don't know if the same phenomenon occurs with the "no Bluetooth" version. 🤔
Also, mine at each boot does a full scan of the SD card. Never the m1s. It only takes a few seconds (it's really an hyper fast operation ; 128 go SD card), but I don't understand the point.
Apart from its few annoying points, and therefore this decline in ergonomics, it's really flawless, and especially from a sound and musical point of view.
If you are looking for an essentially transparent and balanced and vivid, and colourless (but full of colors, textures, etc.) DAP : repeat, this is it. :L3000:
Jul 9, 2023 at 12:33 PM Post #95 of 593
Hello to all.
This is my humble opinion on this great DAP.
https://www.head-fi.org/showcase/aune-m1p.26603/reviews#review-31201
Jul 10, 2023 at 12:53 AM Post #96 of 593
Aug 12, 2023 at 1:54 PM Post #97 of 593
I wonder... how this M1p in comparison with Shanling M1s?
Both seemed to use the same DAC chip, analog (opamp based) amplifier and Linux based player...
Aug 14, 2023 at 6:52 AM Post #98 of 593
ive just bought one seems like a more up to date version of the old plenue d2 i have but with bluetooth and a much worse battery lol
will post impressions when i get it. not really about the sound but about the ui etc
Aug 15, 2023 at 1:36 PM Post #100 of 593
the aune is here and I really like it. its a big chunky boy tho compared to the little sony a306.
im testing it in bluetooth reciever mode (tidal) and it works really well and give a very pleasant sound. however i can control the volume on both the aune and my Android device. what is the recommendation in this mode? full volume on source (android) and then control the volume using the receivers (aune)?
thank you
Aug 16, 2023 at 8:56 AM Post #105 of 593
you can hold down the middle circle button and it acts as a back button. it works well.
ok I will try, thanks :beerchug:
But it was so convenient with the old model :stuck_out_tongue_winking_eye:
