AUDIOSENSE in-ear monitors Impressions Thread
- Thread starter FastAndClean
RikudouGoku
Member of the Trade: RikuBuds
The 2 holes probably have some Knowles filters for the 2 ba in them. Im guessing that each bore leads to each ba driver.Hi there,
The metal nozzle from the right iem of my AQ3 pulled out when I was changing eartips.
Any advice regarding a safe glue I should use?
By the way, two of its holes are closed/has some stuff inside. Should they be like that?
Thank you
rprodrigues
You are right. Each of them leads to a different BA.
I think it was glued with fotofix you should ask audiosense what glue they used
Hi there,
Thank you
I had the same problem and you can either ask Audiosense to send you new ones or glue it back yourself. I used a tiny amount of superglue and so far I had no problems, but asking Audiosense may be the more responsible way to go!
rprodrigues
I am willing to use superglue too (from loctite) but I'm a little bit afraid. I thought it could damage the resin.
I've already asked Audiosense and will wait for an answer from them although I guess I will have to do the same you did
Thank you.
Thank you.
In my case they also offered to send a new pair and send back the old one. Their customer service is great!
I used https://www.amazon.de/gp/product/B004T2M0BC/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
rprodrigues
Thank you for sharing.
Glue it back is a better solution for me.
At least it is the fastest one.
Guys, anyone has paired t800 with hiby r3 pro? How does they sound? Do i need only balanced output to get the best sound from them?
For me balanced sound on everything better. Try it
- Jan 29, 2010
Today we look at the AudioSense DT200 on Headfonia!
https://www.headfonia.com/audiosense-dt200-review/
rprodrigues
Hi there,
Thank you
Updated:
Audiosense told me that I can use superglue but an epoxy resin AB glue is prefered.
I just want to know how t800 sounds with hiby r3 pro. No info on the internet about those 2 together.Guys, anyone has paired t800 with hiby r3 pro? How does they sound? Do i need only balanced output to get the best sound from them?
thesheik137
Nice review, very much in line with what I am hearing as well. DT200 is my easily new favorite IEM under $200. Perfect fit, amazing build quality, and cohesive, fatigue-free sound with still a good amount of technicalities from "just" 2 BAs.Today we look at the AudioSense DT200 on Headfonia!
parawizard
Realized that I didn't get the three different sizes of foam tips but just all large with my T800. Did everyone else get reds, blues and blacks or just blacks?
