castleofargh
Sound Science Forum Moderator
- Jul 2, 2011
The fact that something different happens in the brain does not in itself demonstrate an impact on our experience, and certainly does not demonstrate we can be aware of it.You are right. The paper demonstrates that there are indeed subconscious benefits from high-resolution audio with inaudible high-frequency components, as seen in increased eeg alpha and beta power and improved "inactive pleasantness" ratings.
Gregorio's claim that the study contradicts your point is wrong. The paper shows that although participants couldn't consciously distinguish the audio versions, their brain activity and relaxation scores demonstrated clear, measurable differences. The increase in alpha and beta eeg power, combined with heightened "inactive pleasantness" ratings, demonstrates that high-frequency components in highh resolution audio subtly affect listeners in ways that go beyond conscious awareness. Just because the difference isn't consciously detected doesn't mean it doesn't exist—it’s reflected in both physiological responses and subjective mood shifts.
I'm sure he'll apologize and retract his insults.
Correlating some type of activity in some area of the brain with some emotions and then some type of activity around the same area with music+ultrasounds over a period of time, to conclude a relation between the emotion and ultrasound, that's at best, thin correlating evidence. We can't really avoid relying on correlated evidence in psychology(because that tends to be the best we'll ever get, not because it's good enough to know anything for a fact), but a correlation to a correlation is a far cry from fact.
As for the rated feelings, That's just not serious at all. I've read how much effort went into trying to get a meaningful scale for pain in hospitals, and how big the margin of error remains for many probably unsolvable reasons. So making those opportunistic casual ratings of many vague subjective concepts, with a relatively small number of people, it doesn't say a lot. What does active and inactive pleasantness even mean? Apparently some guys gave a high arousal score to the low passed music. Too bad it didn't go in the direction you care about, otherwise we might have ended up with a statement about how CDs make a few people super horny.
I do not think the paper demonstrates subconscious benefits like you wrote. It only makes tentative correlations and never comes close to talking about proof. They speculate a little, propose some ideas(not pretending that they're anything more than ideas), and wrote
It remains unclear what kind of advantages high-resolution audio might have for human beings.
Now, there seems to be some coherence within the findings, and that's encouraging. If we take the idea that the impact is delayed and lasts for some time after the sound stops, and the idea that it does end up manifesting as some small specific change in the subjective experience, then it would make sense for typical blind tests to fail.
But now that they have those ideas and early validation about the possible duration of the effect on the brain, they could set trials outside those time boundaries. And All those guys surely thought about it right away because it's obvious.
Maybe it's a matter of having busy schedules with work programmed for years in advance, maybe it's about finding a sucker to pay for those trials, maybe they already ran some small scale tests that didn't support the "let's have people rate long lists of stuff until luck gives us a statistic result we can exploit", so they forgot to publish about that? In any case, let's wait for such trials to show up, or more credible work to be done on the subjective feelings turning into conscious emotions because it's literally the first time something supports that idea, before saying that it demonstrates anything about anything. Certainly, it does not support or even relates to anything @eq1849 has been saying.
What has not been proved AFAIK(tell me if I'm missing some paper):
That it is a hearing thing. Would ultrasonic vibrations on my feet manage to also create similar impact in my brain? IDK.
That the ultrasonic signal matters. Would adding ultrasonic noise to a CD show the same activity change in the brain? IDK.
What has been long disproved:
hires does not improve the perceived details, it does not open the soundstage, it does not increase the micro dynamic, it does not give more air, it does not make the image more precise and expansive. It does not do this
In the long term, for me, 16 is flatter and less clear. 24 has more weight and clarity. Since buying 24 bit since 2014 or so this effect has never gone away and is extremely consistent to me.
All that is clearly BS. Even the papers supporting the idea of hires having an impact, could never bend backward enough to support all that nonsense about clear conscious impact on sonic properties. If it does happen that someone perceives those differences, and I see no reason to doubt that it happens, then surely it is caused by biases under casual listening, or by bad gear, or bad settings.
To quote Feynman, "if it disagrees with experiment, it's wrong. And that simple statement is the key to science".
@eq1849 can keep using logical fallacies until we can compile them into a full guide, and keep moving the goal post until he gets in the Guinness book of record for most distance travelled with the mind, the audiophile descriptions found on the forum for how hires sounds and feels different is always BS caused by something else. If those objecting to blind testing could spend 1/10th of that useful skepticism pointed toward their own casual experience, they would agree. But are they able to look in a mirror and consider their own fallibility this late in the game, after having invested so much in the name of false audio idols? That's another story. A deeply psychological one.
