Very sad...
although I have a NET iis ddc for VOX,
but HUB always best choose.
Yes, I have seen your posts, thank you for those. I'm running Bullet 1.40 at the moment. The sounds aren't too loud but I tend to be very sensitive to them and they just start to annoy me. I was hoping the Hub would have been out already since Nicolae and the dealer say it will stop switching because of the constant upsampling. If that takes too long I'll see if those DC offsets help. If I remember correctly you have to open it up to make those changes?Thank you for your impressions. If you have seen my initial posts. I too had this problem during format transitions and was resolved by a FW update (1.39) + some DC offsets. Now using I2S thru Singxer SU-6, however clicks still remain during device locks.
Went to the Play Store and saw another Audiobyte app (Hydra Remote) but this is for an older product.
I hope you're right but I'll believe it when I see it. It has been pushed back enough times already. I just told my dealer to contact me when it's available.Any update on Hub? Manufacturer said April..
The Android app only connects immediately for me when I start the app. When the app is running in the background and I switch to it, then it takes ages to reconnect. It's faster just to kill the app and restart it. Luckily you don't really have to use the app very often so it's only a minor annoyance.Goodmorning everyone. I've had it for about two months. The sound quality of the DAC is certainly excellent with the plus of its power supply. For the defects found by me everything works perfectly, the Android app is fine, it hooks up immediately and does its job. The clicks of the relays to change resolution obviously are there but they are not really a tragedy ... For the noises with USB connection I have never heard it. I use Mac Mini with Roon core, Qobuz and hard disk files. The analog variable volts output I believe is for powering an external device.
Sounds great and looks like a really interesting device. I'm definitely going to add a Roon enpoint but I'll be waiting for the Hydra Hub since it's a reclocker/upsampler/Roon endpoint and will connect to the Vox with I2S I believe. It should be out soon but I don't mind having to wait a few more months.Let me only suggest with roon core and Hydra Vox+Zap to add an roon end point like my SOtM sMS200 Ultra, it's a very good upgread unstead of USB cable direct to DAC. Very low noise level, more effordless sound and holographics 3D pin-poing soundstage.
If it is like with the Wavelight, the Hardware setup is finished, but due to corona there are delays for parts.Sounds great and looks like a really interesting device. I'm definitely going to add a Roon enpoint but I'll be waiting for the Hydra Hub since it's a reclocker/upsampler/Roon endpoint and will connect to the Vox with I2S I believe. It should be out soon but I don't mind having to wait a few more months.
