tamahome77
If one just wants the hydra hub and not the DAC, does one have the option to purchase the hydra zap separately?
Right, so I had some time with these boxes and here are some of my observation
Day 1
Slightly dark sounding with a a slight emphasis on bass
While the details were forthcoming and clarity was great, it sounded a little closed
Soundstage was not as wide as I expected but the depth was excellent
Day 2 onward
The slight bass emphasis had receded and overall tonality had lifted, resulting in a more noticeable opening sounding
No longer slightly dark sounding but largely neutral and rather clean sounding, but never in your face
Soundstage improved noticeably too, with good width to complement the excellent depth
The Vox has a rather big sound, I attribute this to the supercaps in the Zap
It is a great sounding DAC, largely neutral and very resolving and this allows the musical Sugden Class A and Monkey 93 to sing and express themselves
I'm running the Amp and Sound Kensie encore through single ended connection and it sounds the same as balanced to me.Has anyone bought this specifically to be used with SET amps? I'm interested in getting a new dac and has shortlisted the hydra stack as one of the candidates for my upgrade. I'll mainly be using this with tube amps and won't be able to take advantage of it's balanced output so it is important for the single ended performance not to be compromised.
That is reassuring. Great amp btw. Will post some impressions if I do end up getting this.I'm running the Amp and Sound Kensie encore through single ended connection and it sounds the same as balanced to me.
