Vertigo,
that's a very fine review! I feel you have conveyed your hearing impressions very well.
Okay, now for some comments:
If the W100s have one glaring weakness, it's the bass. It lacks visceral impact (not a bad thing at all in my case, but probably a downfall to the bass whores out there). It also lacks grunt in the lower registers, i.e. I can barely make out cello string plucks. That low tone resonance and extension just seems to be not there. I have no complaint however with upper bass notes, such as low piano notes...I hear excellent decay there. |
The W100 bass mystery - will it ever be solved? My pair has the most realistic, believable and musically captivating rendition of low notes I have ever heard in a headphone. In terms of extension and slam, it's clearly superior to heaphones like the DT931, the DT990 Pro or the HD600. The only headphone I know that has bass reproduction more visceral than the W100 is the DT770 Pro (I don't know the W2002, though). The 770 Pro has slightly better extension but loses in any other conceivable area: it is less tuneful, it has less timbral fidelity and it's simply less musical down there. In the beginning, however, the W100's tonal balance and bass reproduction has been a disaster. I only started to see potential after maybe 50 hours, but then it kept improving for hundreds and hundreds of hours. Even after 300 hours, when I set a bass-heavy track on auto-repeat for the night - as I ocassionally did before - the W100's bass response noticeably improved. Another thing that will extend the W100's bass response is a tight fit. As suggested by JML, it may help to bend the connecting tubes a little, into a more oval shape, in order to increase the headphone's clamping pressure.
As you said, Vert, the Sugden may have something to do with this - I use the EMP - but frankly, I doubt it. Whatever garden variety headphone jack I plugged the W100 in: to my ears, it worked great. There is one thing I cannot rule out, though, and that's major production variance due to the wooden driver housings. I have never heard another W100.
Just a side note on a piano's frequency: the lowest note on a concert piano is at 27.5 Hz, the lowest note on a cello is at 65.4 Hz. So a piano can go more than an octave lower than a cello.
Originally posted by The Quality GuruI find that in some passages this headphone is not very listenable- though mostly due to the reverberations that I think are somehow added (mostly to voices it seems) creating an artifical "concert hall" effect and subsequent reverberationns that prove horribly annoying. |
Originally posted by Vertigo I think I've heard that echoey effect on one track in particular, Keiko Matsui - Light in the Rain. The opening starts off with a quick series of drum hits...those drum hits seem to create such reflections as to make me feel as though I could clearly hear the recording venue. The band in this track sounds very encapsulated...you can just hear everything bouncing around this tight little space. I tend to think this is good ambient environment retrieval, but this could very well be the headphone casting reflections into the music. |
I'd say the W100 excels at ambient retrieval. I feel that I can perceive the size of a recording venue with the W100, that I can hear the low sound waves bouncing off of the walls. That is something the DT770 Pro is very good at as well - and reportedly, so is the W2002. If a recording hasn't been recorded and mixed all too well (e.g. The Sympathy for the Devil album by the Stones) you can hear the sonic properties of the different recording locations superimposed on each other. When Mick Jagger's voice track enters, quite often he seems to sing in a space all of his own - what I interpret as the small recording booth, his voice has been recorded in. Those ambient clues are things that actually are captured in a recording but that one will probably never be able to hear with a speaker system. To me, this isn't really distracting and the musical benefits of the W100's extreme low-level resolution and of its ambient retrieval far outweigh the disadvantages.
Quality Guru, you talk about the "reverberations" that seem to have been added mostly to voices on some recordings. Are you talking about popular music? That's what they do there all the time, adding reverb, especially to the frequently rather thin voices of pop singers. Once again, I'd say it's very likely that the W100 simply shows you what has been recorded (and mixed and mastered). To my ears, the W100 is just a very transparent and natural sounding headphone that simply steps back, so I can listen to the music. I love it.
