Originally Posted by Nik
I mean that the sound is produced by something in movement, vibrant, that in the guitar is the surface (and strings tha do not are parts of the instrument). All the parts of the instrument have a work to the best performance of the guitar, but no all produce that sound. The back and the sides work reflecting the sound out of the instrument as a "passive amplification".
That statement is misleading at best.
I currently own approximately 20 guitars, and the back and sides of each single one vibrate when I play them. It is crystal clear that back and sides "produce" a guitar's sound, just as the top does, and that is precisely why a guitar's sound changes when the material for the back and sides is changed. It is very easy to understand that this is due to more than mere reflection.
The top is glued to the sides and the sides are glued to the back. If the top vibrates, the sides will vibrate too, and that vibration is transmitted to the back. Consequently, back and sides vibrate just as the top vibrates, and they therefore shape the sound of a guitar just as the top does. If the back and sides of your guitar don't vibrate while you play, there must be something wrong with the guitar. But I presume they do.
If there is such an effect as "passive amplification" by reflection, it would be best to make the back and sides of guitars out of a totally non-resonant, reflective material. This has been done since the late 60's by an American company called Ovation. Their guitars have plastic/fiberglass bowl-shaped bodies with "real" wooden tops. That's also how they sound. N.B.: These guitars are very good for amplified stage work, as they do not readily feed back due to their lack of sensitivity to vibration, but "unplugged" they just sound like plastic. This demonstrates clearly that a guitar's sound depends on many more factors than just the material of the top.
In a traditional wooden guitar the degree of "passive amplification" (the "gain", metaphorically speaking, or simply the loudness of the guitar) is determined by the size and shape of the body much more than the chosen tone wood. The tone wood determines the sound, the body size determines the volume (as a general rule).
It still isn't clear what any of this has to do with the W5000's. Back and sides of a guitar are most certainly NOT "dumping parts".
