cityle
- Apr 22, 2015
Just wanted to say that there is these clips on the headphone and you clip down the plastic ring underneath the earpads on them.
Sorry - cant find the official R70X discussion thread but wanted to know if the connectors are 2.5mm and if they are some sort of proprietary locking mechanism? Or would any 2.5mm connect work
I'm thinking it would at least be a raised 2.5mm connector, they sockets looked recessed a bit
Thanks!
I recently re-acquired the R70x because the last time I had them (which was back in June/July), I had a sneaking suspicion that it might sound similar to the Sennheier HD600 and wanted to confirm for myself if that might be true. So I just picked up a set of the HD600 too, so I could find out.
The short version is that yeah, the R70x really does sound a lot like the HD600! So my suspicion was true after all.
A longer version of how the two headphones sound similar (and yet different) will be coming later, since I got the R70x to write up a full review of it this time. I have an AKG K712 coming in as well, since I thought that would be an interesting comparison point too.
I've heard that the MSR7 is highly uncomfortable, is this true]
I find msr7 uncomfortable
I got a second hand HD800 pair for almost a week now, it completed turn my mod M70x sound metallic and harshness. If you like the sound signature of M70x, IMO, you should audition HD800 once if you can. The HD800 sound sooooo lively and beautiful
However, HD800 is an open can so it leak sound alot, I can't use it at workso use HD800 as reference to mod M70x (i also have Hifiman HE 560): reduce metallic and harshness, improve bass.
1. Remove yellow foams behind drivers and black rubbers (cover vent hole?) ==> slightly improve bass
2. Use a thin Closed cell polyethylene foam sheet, cut a hole in center. Use double side adhesive tap (as much as possible on the polly cell foam sheet) and stick it to the housing as picture below ==> this will help seal most of unwanted leak air for bass improvement & help damping the back wave
Note: if you use the stock pad, you should trim the poly cell foam fit with the gray foam of the housing. I use the Audeze leather pads, it cover all the housing surface.
3. At this stage, the M70x sound boxy ==> you have to poke a hole or more as your bass taste (red circle, you should see a line of wholes on the housing frame when remove the yellow foam). The size of the hole about 1mm (i used toothpick)
Please note the the driver is angled, so half size will very close to the earpad and other half has some spaces ==> poke hole in the half has spaces.
This simple mod (and reversed able) will significant improve bass performance, slightly reduce metallic and harshness sound ==> make your M70x more enjoyable.
If you think M70x lack of bass impact (not bloated), think it again with this mod
