bassophile
- Aug 17, 2010
Do these earphones come boxed with replacement filters in case one/both of the filters becomes clogged with ear debris?
From pictures I have seen, the filter lies very near the tip of the nozzle, thus any dirt from the ear tip is likely to go straight into the filter.
CK10 owners, have you noticed this as a problem, or are you able to clean wax and the like before it reaches the filters? If it IS a problem, how have you dealt with it?
I was thinking of using one of those Tx series Comply tips with the integrated wax guard, yet, on the Comply site they do not specify which Tx series tip would be compatible with the CK10.
Finally, where is one able to purchase the replacement filters? Indeed, are the filters even user-replaceable, or must you return them to the manufacturer for this service? And is this service even offered?
Thanks for your time!!
