Nostoi - Yep, I have Shark Island and Red Dragon Cartel. Over the last couple months, I've found a ton of new stuff - Really been digging deep. I've discovered Trans Am, Treat, Fierce Heart, Shotgun Messiah, Slave Raider (EXCELLENT), Every Mother's Nightmare, Hericane Alice, Rough Cutt, and a few others. Check out this website if you aren't familiar with it.
en.metal-tracker.com
Just browse or use the search function. Downloads available for everything. I finally found the entire discography for Dirty Looks!
I'm referring to the original recording. Any advice you have file types is definitely welcome. My friend and Co Worker just kinda dived into formatting head first. So we aren't as educated as most, but a lot of our files sound pretty incredible. He does most of the legwork, and uses Foobar I believe. I use EZ CD converter / ripper, but only for CDs.
I use my LG V40, and also used an Opus#1s for several years. I recently sold it, and replaced it with the Hiby R5. I prefer the Cirrus chips over the ESS chips in my V40. Not necessarily for everything, but for what we primarily listen to, most definitely. I don't own any home audio gear. I purchased the upgraded Audio Technica 2.5mm balanced cable some time ago. My R5 has the 4.4mm balanced connection, so I'm debating on upgrading all of my cables, or just sticking with an adapter. I just ordered the 4.4mm pure silver balanced cable from Meze Audio. It works with both my 99 Classics and B&O H6, which I had modified for balanced use. What's really nice is that this cable will also work with the T5p 2nd.
I am semi treble sensitive, and the Msr7b is about as much as I can handle. I had to lower the 2 and 4k a decibel or two, in order to use them for long periods of time. That being said, is it possible that the T5p 2nd could be a bit much for me? If I could find a headphone that combines the best traits of both the 99 Classics and Msr7b, I would be feeling pretty good. I would also like it to be a more grown up can in general. I appreciate some good air around the instruments, and excellent separation. A giant Soundstage isn't all that important to me, as I've found it isn't necessary and doesn't always jive with busy, heavy hard rock. I appreciate both attack and decay. Dynamic, energetic, and musical is what I'm after. A quick, snappy and punchy low end. No bloom, and slightly North of neutral. I don't necessarily need a mid forward presentation, but they can't be recessed. Guitars and male vocals need to be engaging and sound fantastic. The mid presentation is different on the 99 Classics and Msr7b. The 99s have more weight and crunch, while the Msr7b is a little leaner with more speed and sizzle. I'd be perfectly happy meeting right in the middle if that makes sense. I apologize for length of this post. I just want to get it right the first time. This is a lot of money for me to spend. I haven't exceeded 300 dollars on a pair of cans yet. Perhaps now that you have a better idea as to what I'm after, maybe you can help push me in the right direction. Eventually I'd like to own both. If you would rather discuss this over PM, just let me know. You've already helped me out quite a bit, and I definitely appreciate it. I'd also like to know how you obtain and convert your files. I'm sure you have more experience than I do, and any assistance would be awesome.
