Audio-Technica ATH-MSR7 Discussion Thread
Discussion in 'Headphones (full-size)' started by lalala6, Oct 17, 2014.
139 140 141 142 143 144 145 146 147 148
150 151 152 153 154 155 156 157 158 159
  1. woodpecker
    True, nothing beats the IEMs in terms of noise insulation. Anyway, the MSR7 are not completely sealed, they have a hole on top of the cups, which lets the noise in and out. You can experiment with some blutack to seal the opening, but you will surely alter the original sound signature...
    You could have a look at the Tyll's measurements of isolation for sealed headphones at Innerfidelity. It might give you an idea where to look further...
    zazex likes this.
  2. guisess93
    I can't seem to find the hole on top of the cups you mentioned...
  3. riposte
    guisess93 likes this.
  4. Cruxiaer
    [​IMG]DSC02113-2p by Chia Way Tan, on Flickr
  5. guisess93
  6. woodpecker
    Nice photo indeed! Can you also shoot the lower one?:)
    As Riposte suggested, there is one more opening at the bottom, somewhat harder to find...
  7. guisess93
    I already found the one at the bottom. Thanks a lot guys
  8. Cruxiaer
    Its here if you haven't found it yet.
    [​IMG]DSC02109-2p by Chia Way Tan, on Flickr
  9. Ducman1806
    MSR7 comes with a 3.5mm detachable cable that is compatible with smartphones however I read that using a lighting cable gives you a better sound quality so should I buy a lighting to 3.5mm cable like THIS one to improve sound quality or it's not true?
  10. theaudiologist
    guys is the normal 3.5mm cable that comes with it good or is it better to buy something? any suggestions?
  11. headwhacker
    no need to buy aftermarket cable. AT provided 3 sets of cables for 3 different usage scenarios. The cable build quality is already very good.
  12. theaudiologist
    i'm talking soundwise, does it ruin the sound?
  13. wormcycle
    Only is you separate a cable from the connectors. The plugs of both short cables are one of the worst I have seen. The connection on all three portable devices I own is wobbly and the shape of the plug makes it sensitive to even small movement of a cable. And I had two pairs of MSR7.
    My DIY Mogami cable with high quality Eidolic connector is a big improvement.
    Smokescreen0623 likes this.
  14. headwhacker
    I have 2 MSR7 and don't have any issues you mention.
  15. Coop
    Same here (ok, only 1 MSR7), no problems with the cables whatsoever. Solid connection on all the devices I use it with (A&K AK70, Hidizs AP60, Fiio X3 1st gen., Headstage Arrow 4G with the regular short cable, Samsung Galaxy S4/S6/S8 with the headset cable, the long cable I hardly ever use). I swapped the stock cable for the homebrew Mogami cable I made for my V-Moda M100 and there was a difference, but not enough to make me want to make another cable for the MSR7.
