ZapX629
- Dec 28, 2013
These look very interesting. How would they compare, in terms of sound alone, to the
1. HiFiMan RE-400,
2. VSonic VSD3S and
3. Zero Audio Tenore?
I presently own a VSonic GR07 MkII, and coming from someone who works in music production with studio monitors and studio-grade headphones, I find the GR07 MkII lacking realistic bass weight and fullness in the low-end.
What are your thoughts?
Ok, so in comparison to the GR07 these have quite a bit more bass, a tad less clarity but equally good, if not better naturalness, more full and warm sound. Low mids are a tad more recessed but the mids then come up in the upper region and feature female and higher male vocals more prominently. All the comments of the mids being natural and heavenly and all that are spot on. The highs are less sibilant and balanced with the rest of the signature, and again, very natural sounding. Soundstage is about as wide and deeper. Separation and layering are on par. I don't know that they'd be the best choice for a reference monitor, but they definitely will give you a weightier and beefier low end, while staying well controlled like the GR07BE does while being a little more boomy. You might like the GR07BE better for monitoring purposes as the bass isn't quite as boomy as the IM70.
In reference to the VSD3S, it sounds a little more artificial than the IM70, but has a similar soundstage, just not quite as deep or wide. Treble is harsher and could be more fatiguing. Clarity is better on the IM70. Bass is again, much boomier and thicker on the IM70 but still holds up to fast phrases better than the VSD3S. Mids are more recessed on the VSD3S. Separation is a but behind the IM70s.
Just some quick thoughts while playing with the IM70s after a 10 hour or so burn in (didn't hear any real change out of the box) and I'd be happy to answer any other questions you have about them.
