Audio Technica ATH-E70, ATH-E50, ATH-E40 IEMs announced at NAMM 2016
Apr 24, 2017 at 1:46 AM Post #871 of 1,068
  Well, this is from here http://www.hybridaudio.ru/photo/CID_32.html. Not sure if he still has this type of copper.
That cable I have for 2 years I think. I just changed mmcx to a2dc today myself.
 The cable does not look very sexy but sounds awesome! 2.5 mm TRRS balanced.
Could not read Russian :), but I found this - http://www.ebay.com/itm/OFC-Silver-Plated-Upgrade-Audio-Cable-For-Audio-technica-ATH-E40-ATH-E50-E70-/292083009108?var=&hash=item4401810654:m:mRz9e1k7K1JzFrc0f0v53bw . It does not specify the % of silver though.
Anyone has tried that before?
Apr 24, 2017 at 10:51 AM Post #873 of 1,068
So my Shure215 died and need a replacement, feel like trying something new.
I kind of like the Shure215, but would like something with a bit more resolution while maintaining the bass kick.
I am thinking ATH E-40, E-50 or CKR 9. They are not too far apart price wise, what should I pick?
Apr 24, 2017 at 11:05 AM Post #874 of 1,068
If you can spend around $170, I will suggest go with LZ-A4 instead. They are offering discounts as well on Aliexpress.
May 5, 2017 at 2:19 PM Post #876 of 1,068
A few days ago , i had a chance to try the e40 and here are some my thoughts :
it's a little big but i still can wear it comfortably (for 15-20 mins) , the nozzle angle is kind of weird that i thought it might hurt the ear canal but it's not so no problem with the fit and comfort . With stock tips
the sound is enjoyable (easy to listen to) , the bass is just right for my ears and i think it's mid-focused or has emphasis on the mid (maybe) , the singers alway have their space to show (notice a little reverb on the vocals) ...
i need to listen more to correct my impressions , maybe i will get one later
May 14, 2017 at 1:36 AM Post #877 of 1,068
I used to think the cable thing was BS till today and I was wrong. I got the customized cable for E70, with 4N copper and silver(10 thread copper and 5 thread silver mixed, not plated). The bass is tighten up, smoother. The vocal separation is better.
Now, I am wondering how the ATH official upgrade cable sounds? Anyone tried?
May 14, 2017 at 11:19 AM Post #880 of 1,068
Found E70 scale up with the cable? Now how do you feel about E70 vs LS200 under the same cable?
Well, it did scale up last time with the Black Caviar cable - now it is just more or less at the same level, a little bit brighter sounding I think.
I still like the LS200 but they sound flat in comparison. And yes, the bass is just great on the E70.)
I'm waiting for a portable amp to pair it with Vantam, so the E70 will have all chances to become my number 1 )
May 14, 2017 at 11:33 AM Post #881 of 1,068
Is that a tube amp? I'm attempting to get a fostex portable tube.
I guess at some point the cable upgrade will have diminished return.
May 14, 2017 at 11:28 PM Post #883 of 1,068
Hi All,
ATH-E40 is it power hungry? Wonder IiPhone 7 plus able to drive it alone?
Thanks
nobody
May 15, 2017 at 11:22 AM Post #885 of 1,068
Hi,
Thanks. I bought it and try out spiral dot but seem quite easy to fit it in. WIll there be any leak sound ? With Spiral Dot Bass more fuller but seem cover up the high... How does spinfit perform with E40 ?Anyone ?
Thanks
