mayank11280
I haven't heard the E80. I will try to do an A/B of the MA750 and E40 later today. Suggest a couple tracks to try them with on Tidal and I'll tell you the differences I hear.
Build quality on the E40 seems fine. Cable is replaceable, which is good (the cable that comes with it is too long and feels cheap, however). Nozzles are a bit long and (good quality) plastic, which could maybe be a concern if you abuse them. But if you use the provided hard case they should last for a while.
Thanks again for your reply!
I always use case, I can not watch any of my IEMs getting damaged.
Though mostly I listen to Indie and Rock, the likes of Let it Happen- Tame Impala (my goto track when doing A & B), Mister Asylum- Highly Suspect, Heart is a Drum - Beck, Vesuvius - Sufjan Stevens. These are the tracks which can tell my preference and are the tracks which I use to test my IEMs.
