usernamewillis
- Apr 5, 2017
Thanks qsk78 for the comparison. I got the e50 in the end since I'll be using my laptop and phone to power it. Been enjoying it so far!
Good! Are you going to try spiral dot as well?
Not yet but new 2 flange spinfit CP240 on their way...
I would like to admit that with spinfit tips I do not get that much amount of hissing with the E70.
It is not gone completely and I still hear it on some tracks with a lot of percussion but it is acceptable now. Can live with it.
not the e70 causing hiss either music or source
How is the size compare with spinfit and ATH original one? Trying to figure out what size I should buy. the original M is a little small for me, but L is a little large.
Hey guys, I am torn between E40, RHA MA750, RE400 and a lower budget SoundMAGIC E80. A little help will be appreciated.
I am mid head guy, I don't like overpowered bass like in Sony's XB series, SoundMAGIC E10, Beyerdynamic DTX 102... I am looking for an upgrade from my beloved E80 as I lost it.
I have owned all except the E80. I would rank them E40 first (balanced, not as detailed as E70 and with less subbass but still really good for the price), then ma750 (very nice, excellent build quality and warranty, but with a bit of a midbass hump and sometimes metallic / strident high mids), re400 (no low end at all, poor build quality - don't understand the hype on these).
Thanks a lot for your prompt reply.
That is the exact same reason why I was avoiding RE400,the build quality is questionable.
Can you give an A&B comparison between E40 and MA750?
And how is the build quality on E40? Have you listened to E80? What's your take on E40 vs E80(SoundMAGIC).
I would highly suggest the E40. it's an amazing IEM for the price.
Very wide soundstage and excellent detail retrieval. The bass quantity is also perfect - being a bit above neutral, still it sounds slightly bright and doesn't sound warm. Vocals are upfront and awesome. It's really good across all genres, plus you can get a taste of the ATH colour. Just go for it.
I must also admit that i've not heard any of the other IEMs you have listed, but from what i've read, i don't think they can come close to E40's push-pull configuration
