ElcomeSoft
- Jan 11, 2011
Cool what about spiral dots? they make a really big difference with bass http://amzn.to/2lO2QMn
Too expensive to even consider, even moreso than the V-Moda BLISS tips.
cool, i notice the e70 competes with iems well over $1,000. You have any high end iem you compare it to?
Odd question of the day...
Will the V-Moda Bliss 3.0 tips from their Fader line of earplugs fit the E70's?
Everything seems to look like a yes but you can never be too sure.
Although they're an expensive way to get some tips it's the cheapest way in the UK so far and I'm wondering how they'd cope with my daily commute for those days when IEM's aren't my choice.
yes i use vmoda bliss and they are the best tips for e70.
I don't find the e70 is too dark either. Might depend on the output impedance of your source. A near 0 one will make them sound brighter I guess.
Will get my e70 in 1-2 weeks from now. I like the e50 a lot, hope the e70 will keep the tonality of the 50s. I listen to mainly technical death metal, so bass speed is critical, that's why i do not own any dynamic type of IEM.
Looking forward to your comparison btw e70 and ls200
I will. Actually I don't want to keep three Audio-technica. Two will be more than enough))
So one will be sold out. I predict it will be very hard to choose.
