Halimj7
- Mar 2, 2012
Does anyone know where to find a frequency response for these? Thanks.
Yes, thanks and those were exactly my same points, it was simply a reply to the chap who wanted a frequency graph. It would have been of more value if there had been an IEF neutral curve on there for reference .I think the graph is fairly accurate but the bass looks strange because it starts at 0 which you don't see people do with measurements. I also care about how they sound and not how they measure but graphs can give you a sense of what the headphone might sound like but I never take too much stock in them because I've seen some bad looking graphs on headphones that sounded good.
Not sure about how they compare to the M50X, but they are not dissimilar to the MSR7b if you have heard them. They have a small bass boost and then neural mids and a slightly elevated treble I would say. They are good on vocals and soundstaging. They are also quite dynamic so should be god on classical (but I don't listen to this genre).Hi everyone, I'm interested in the ap2kti. Are these good for classical and electronic music? Is the sound signature similar to the cheaper m50x?
Ok great stuff.Yes, it helped, thanks for your response.
How's the imaging?
Are male vocals "thin" due to the slightly recessed mids?
As far as i can see from the specs they should be easy to drive, do they benefit from more power or does it enhance the sparkle of the highs?
Hi! I’ve got the ap2kti’s with a RME dac and it’s great! I listen to most styles and this can handles most. Vivaldi sounds great and electronic music like Infected Mushroom also. Go buy a pair!Hi everyone, I'm interested in the ap2kti. Are these good for classical and electronic music? Is the sound signature similar to the cheaper m50x?
Great tip about the pads. Wich kind did you choose?I listen to a lot of electronic music and I think the ap2kti sounds great with it. There's enough bass and the highs really help to bring a lot of energy to the music and to me they don't sound overly bright but they are brighter than the M50x. I recently changed the pads to some Brainwavz that aren't angled but they are thicker than the stock pads and I feel like they have helped with the soundstage quite a bit and they've also brought the highs down just a touch. So far I like how they sound now more than with the stock pads though the change is small but noticeable.
Yes I think that’s a fair assessment.Would these be the appropriate upgrade from the Msr7b? Could they be considered the more mature version? From reading through this thread, I gather they may have a touch more bass quantity, with better depth and layering. Also the upper mids and lower treble aren't quite as strident, and a touch more relaxed. Does this sound accurate?
Excellent. Have you had the opportunity to listen to both? Hoping the TI has better resolution, imaging, dynamics, and just an overall cleaner presentation.Yes I think that’s a fair assessment.
Yes indeed, I have both. Originally I was going to replace the MSR7b with the AP2k but in the end I kept them as they are handy for using with my laptop and are more portable if space is limited in a backpack. The Ap2k is more extended in the bass without bleeding into the mids or being boomy. The mids and treble are more neutral with better soundstaging in depth and width.Excellent. Have you had the opportunity to listen to both? Hoping the TI has better resolution, imaging, dynamics, and just an overall cleaner presentation.
