joelha
- Oct 25, 2012
I just got uRendu yesterday and it is clearly the best USB source I've used with 2Qute. The two have excellent synergy and holds its own against the Rednet chain into BNC. I can echo that USB is 2Qute's best input. I need more time to flesh out what I'm hearing.
Grouping roon zones is a slick way to send the signal to both chains and enables quick A/B comparison.
Optical isolation added to the RN chain today improved the sonic image significantly. Best example so far is that I could better "see" guitar strings being plucked with my mind's eye. I felt vibrationally connected to the guitar player.
Mutec 3+ USB should be showing up soon!
When you mention optical isolation, I'm assuming you're talking about running optical cable between ethernet ports, is that right?
If so, I've done the same and I have to say, I couldn't detect a difference.
If not, I'd be curious to know what optical option you're referring to.
Thanks,
Joel
