Iving
- Jun 28, 2015
Thanks Pete,Great, I hope you enjoy the sound improvement as much as I did. I did have some trouble getting it set up. The latest firmware is necessary (install from the Rednet app). It can work direct to the d16, the only catch I found is that I needed both ends connected via ethernet so that they could "see" each other. I think there was some improvement after setting it up and removing the second ethernet cable from the d16, but as I often make changes to dante, I now keep the d16 connected to ethernet
I have my PC connected direct to the D16. No switch. I stay offline but if I need the internet it is connected via the PC. There is no ethernet connection at the D16 except the incoming audio signal. I intend to keep it that way. That is, I will install the card, update firmware if necessary via internet connected to standard ethernet on the PC, and then remain offline with an ethernet connection direct from the RedNet PCIeR card to the D16. Do I understand you OK? Thanks
