peteAllen
Whatever Rednet say, IMO there is a significant audible improvement when using the rednet pcie card over a normal nic. Also, the best sound possible is when the D16 has no secondary ethernet cable attached: only a single one to the PC with PCIE card. The tricky thing is that to connect/configure the Rednet network, you will need to connect the secondary to your router, but once any config changes are done, you can pull out that plug. I leave the d16 & pc on 24/7.
